Results 1 to 10 of 12
Thread: Lock Miter Master
    Nov 2012
    Wapakoneta, OH
    611
    Lock Miter Master
    I shared this on only one other forum for those that may have seen it, but I have some upcoming cabinets to build that will have side panels joined to the face frame by lock miter joints. I had recently bought the bit for my router table, and then picked up the Lock Miter Master to help with the set up (that's the jig for using this forum). This thing isn't exactly cheap considering what you get: less than 1 oz. of aluminum and earth magnets but it is a really precision made gizmo. Anyway, I needed to test this stuff out, so I set the bit up using the LMM carefully following the instructions. Bear in mind, I've never used one of these bits, and this was my first cut ever. I got a near perfect lock miter with the first pass. In the pick, if you look at the outside corner you see I need just a little tweaking, but I got this done in 15 minutes. So if you have some of these coming up, this thing may be worth considering...I'm sure I could have got it with trial and error but this was a heck of a lot easier. Anyway, the pic:
    Independence, Kentucky
    1,354
    Not bad for the first try Fred, It looks like you have a winner with the new jig. I have seen them advertised and often wondered if it was like some of the other gimmicks that I have seen advertised. Thanks for posting, I appears that it is worth getting to set up the bit.
    17,472
    fred i dont know if you have used that joint much but i have found that to leave it thicker on one side like you show is a good thing,, one you can have some sanding room and two the seam if it shows at all will only be seen from one side.. and i now have that little set up jig and think it is a good investment..
    Nov 2012
    Wapakoneta, OH
    611
    Thanks for the tip....I haven't used that joint at all (yet) but will over the next few months as I have several cabinets to build. I'll try a few more and check leaving that thicker edge. I think most folks would find it (the jig) useful (if they need that joint) but I suspect the price makes it a little hard to justify.
    12,251
    How does this joint work when used on say baltic birch ply ?
    Nov 2012
    Wapakoneta, OH
    611
    I'm not sure, like I said it's a first time for me. I may try a test cut on some and see what happens. My belief is that it will be similar to DT's. That is is, it will work but may have some raggedness to it. If I get time to test it, I'll post a picture.
    Nov 2012
    Wapakoneta, OH
    611
    I wasn't able to get to this yesterday, so tried it this morning. Rob asked about BB, and I cut one on some scrap I had. Since I had knocked down the first setup, I redid it and noticed it went a little faster, though as you'll see in the cut I'm still off a hair. Anyway, I was quite surprised about how smooth the cut was...though I'm less sure about increased strength in the joint. It's only my guess that it is stronger (it's certainly aligned better), but I think the plys may not hold as well as hardwood. Regardless, here's how the BB came out when I tried it:
    17,472
    fred, notice that little dip at the end of the cut, that is one problem with making those joints. when you get tot he end you have nothing to maintain even pressure and the part wants to dip in... what i have come up with is one make parts longer, do this joint first before and mortise or other joints so you dont mess up position or you need to maintain the fence a little smaller on the after cut side like a jointer would be....
    Nov 2012
    Wapakoneta, OH
    611
    Yeah, I noticed the snipe at the end of both the test cuts I made...was thinking a longer piece was the only solution.
    Yorktown, Virginia
    5,014
    Quote Originally Posted by fred hargis View Post
    I wonder if a backer board would help?
  1. Master bedroom
    By Chuck Thoits in forum Off Topic Discussion
    Last Post: 04-29-2014, 02:16 PM
  2. New Lock miter bit jig from Infinity
    By Alan Bienlein in forum General Woodworking Q&A
    Last Post: 04-14-2014, 08:24 PM
  3. Ring master for Christmas
    By david swarat in forum General Woodworking Q&A
    Last Post: 11-30-2012, 04:45 PM
  4. For Sale: Lock Miter Bit, 1/2" Shank #129681
    By Scott Turner in forum Old Ads
    Last Post: 10-27-2008, 03:45 PM
  5. 45 degree lock miter jig ideas needed.
    By Jim Suzda in forum Jigs and Fixtures
    Last Post: 03-25-2008, 10:14 PM
