Results 1 to 2 of 2
Thread: SketchUp Pref's Files
    Kansas
    417
    Under the pull down menu 'Window' under Preferences, under the File sections it list Models, Components, Materials, etc.
    Should these be pointed to C:\Program Files\Google Sketchup 6\ "insert folder name here"
    Right now they are pointed to c:\document and settings\etc, etc,. Is this okay?
    Thanks
    EDIT: Also what do you guys use for your ground and sky colors, just something that suits your eye?
    Rise above the rest
    SE Minnesota
    2,550
    Aaron, I have left most of the Files selections the default ones. The only one that is different on my machine at home is Models which I have set to F:\SKP\. I have a second HD on my computer which has a folder called SKP to store SketchUp files in. The default Windows directory for Models is the My Documents folder which is just fine, too.
    As for colors, I have sky and ground turned off and the background color set to white. I'll change those settings on a case by case basis when I am ready to export images. I prefer to work with those things turned off, though.
  1. Import/Export of .stl files for Sketchup
    By Darren Wright in forum Programming, Troubleshooting, and Q&A
    Last Post: 10-26-2015, 06:31 PM
  2. Hand Files?
    By Kris Petrosky in forum General Woodworking Q&A
    Last Post: 03-19-2011, 09:28 PM
  3. pdf files
    By Cynthia White in forum Site Questions and Test Posts
    Last Post: 03-14-2011, 12:46 PM
  4. Saws and files
    By Rob Keeble in forum Neander Tool Questions and Show & Tell
    Last Post: 03-12-2010, 09:33 PM
  5. attaching files
    By roger johnson in forum Site Questions and Test Posts
    Last Post: 11-15-2008, 03:47 PM
