Results 1 to 8 of 8
Thread: Need your help with a box
    Mar 2014
    Michigan
    144
    Need your help with a box. I am making a mitered box with a floating panel in the middle. The panel is 6X12. The dado is 1/4” So, if I am cutting the box using miter cuts which will surround my panel, how do I figure that out? Using 3/4” thickness wood.
    What will be the cut lengths?
    Kevin
    In arte voluptas - in der Kunst liegt Vergnügen - in art lies enjoyment
    Sorry- clueless as to what you are asking???
    Thomasville, GA
    6,000
    Quote Originally Posted by Kevin Sadaj View Post
    When I do something like you describe, or even with a picture frame, I run the dado along my stock before cutting miters. My first cut is a miter on the end of a board. Then, I hold that against the panel, lining up the dado with the corner of the panel, and mark the location for the miter on the other end. Continue for the other pieces of the frame or box sides.
    Bill Arnold
    5,175
    Or, you could draw it up in SketchUp and measure from there. But Bill's way is more accurate.
    Mar 2014
    Michigan
    144
    Thank you for your replies! I think what is going to happen is I subtract a 1/2" from each measurement. 1/4" dado X 2 = 1/2" So if the floating panel is 6X12, my inside measurement is going to be 5 1/2" X 11 1/2"
    I will let you know how that goes.
    Kevin
    Austin, Texas
    1,448
    If the floating panel is really going to float, the inside measurement needs to be slightly larger than 5 1/2 by 11 1/2. If you use space balls to keep the floating panel from rattling, the ideal compression on a 1/4 inch space ball (which is actually 0.26 inches in diameter so it doesn't fall out of the slot) is just under 50% - or assume that the compressed ball is about .15 inches.
    Most floating panel grooves are 3/8 to 1/2 inch deep, and 1/4 inch wide.
    Charlie Plesums, Austin Texas
    9,077
    I'm not sure I've got what your after but, is it something like this?
    box for kevin.skp
    Mar 2014
    Michigan
    144
    That's it, Glenn! Thank you all for helping out. I'll post pics. Taking this slow since I've got 7 boxes to do. I'm having fun with it ... It is a hobby after all. With the way things have been going, it is real therapy, thank God.
    box for kevin.skp
    Kevin
