Results 1 to 10 of 12
Thread: Downdraft table
    Jul 2007
    DSM, IA
    5,719
    Downdraft table
    I've thought of building one of these for quite awhile now...read how some say they work and some say they don't work. A post by someone I follow on Instagram, @fixthisbuildthat, built one over the weekend and that gave me the push I needed to try it. I built it out of scrap MDF, pegboard and ply I had laying around so if it doesn't work I'm only out my time.
    I'm not going to try it out until I get my .5 micron filter for my dust collector which should be here Friday. It's 42" x 22" simply because that was as big as I could go with the scrap I had. From google research, I think some of the pegboard holes need to be made bigger, but will wait until a trial run to see. I have about a dozen cutting boards that need to be shaped and sanded so it will get a good workout this weekend and I'll let you know how it goes.
    Attached Thumbnails Attached Thumbnails 20141015_191357.jpg   20141015_192955.jpg
    My Website
    13,450
    Oh nice, I actually just set aside a piece of peg board for this same project last night. Looks good. I'd be interested to know if you enlarge the holes or not and how that works out.
    30,017
    Looks good, Jeff.
    17,472
    alan bienlien made one here awhile back and loves it he used a furnace fan for the suction i think.
    Jul 2007
    DSM, IA
    5,719
    Thanks guys! Larry, I just went back and had a look at Alan's table...that thing looks awesome!
    My Website
    3,134
    Wouldn't the field area & amount/size of the holes depend on the CFM & diameter of the ducting/hose?
    13,450
    I think you're right Bart, if it was all 1/4" holes, it would take at least 256+ holes to equal the area of the 4" diameter hose. If they are space about 1" apart, then it would take a little over 2 square feet minimum. Now if you're working on a large flat item, it may be covering many of them holes, so something to consider I guess. I suspect the larger holes are to help with efficiency in sweeping some of the dust to the hose though.
    Jul 2007
    DSM, IA
    5,719
    I honestly don't think I'll ever get that technical when it comes to woodworking...but something to think about for sure. If this along with a squiral cage air cleaner will reduce the amount of dust that settles on everything in the garage I'll be happy. Having a 5 micron filter on the DC was causing a lot of this...so hopefully getitng the .5micron filter will help too.
    My Website
    30,017
    ...Having a 5 micron filter on the DC was causing a lot of this...so hopefully getitng the .5micron filter will help too.
    Bingo!
    Thomasville, GA
    5,997
    I built a unit like that a number of years ago and hooked it to my big shop vac. It worked fine, but when I got better ROS sanders and hooked them to a good vacuum, I quit using the downdraft table. There are times I'd like to set up another one, though.
    Bill Arnold
  1. Finally building my new downdraft/out feed table
    By Alan Bienlein in forum Carpentry and Construction
    Last Post: 12-06-2013, 12:17 AM
  2. Communion Table & Stands - Large table done!
    Last Post: 06-03-2010, 07:30 AM
  3. A Lego table to go with the chairs and drawing table that I made last year
    Last Post: 12-15-2009, 02:37 PM
  4. pool table/dining table input welcomed
    By Robert Schaubhut in forum Designs, Plans and Sketches
    Last Post: 05-22-2008, 02:31 AM
  5. Table Saw. Band Saw. Router Table. *** ALL SOLD ***
    By Rob Bodenschatz in forum Old Ads
    Last Post: 05-31-2007, 04:56 PM
