Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Need some help with this design
    May 2009
    Lafayette, Indiana
    2,380
    I want to build a plant stand very similar to the photo below, however I'm having a very hard time figuring up the dimensions necessary to achieve it. The overall height will be 40" tall. The top will be 12" x 12". I was thinking the legs would be 1-1/2" square, set in from the top about 1 inch that should leave 7" between the legs.
    So given those dimensions...what size does that make the center vertical slates if they are equal to the spaces between them?
    So I want equal space between the slates to be the same width as the slates. (does that make sense)?
    SE Minnesota
    2,526
    Would you like I should draw it for you? How thick do you want to make the top? Are you going to add the drawer?
    To be honest, I don't think the slats and the spaces should be the same size but that is up to you.
    5,321
    With 3 slats and four spaces, that's 7 increments. So, with a 7" space between the legs, it's easy. Make the slats 1" wide, and space them 1" apart.
    SE Minnesota
    2,526
    Actually, I was a little curious so I started it. I think the legs look a bit heavy for as narrow at the piece is. What do you think?
    I'd sort the legs out before trying to work out the space in between.
    May 2009
    Lafayette, Indiana
    2,380
    Dave you may very well be correct about the leg size. I was just guessing at that size. I have tried to draw this out tonight on paper but just don't have the skill to do it correct. I like the look of the photo and want to make mine pretty close to that. Yes I would like to add the drawer. I was thinking of even trying my hand at dovetail corners on the drawer. Dave if you have the time to draw it up that would be very much appreciated.
    Glad Dave chimed in. I was going to post "use SketchUp". I think it is too tall for the dimensions of the top.
    SE Minnesota
    2,526
    I'll at least make something that looks close. I agree with Glenn about the height. Could you go a bit bigger? Or shorter?
    May 2009
    Lafayette, Indiana
    2,380
    Yes larger would be ok.
    Height could also be 36-40"
    I simply saw this photo and wanted to build one like it or somewhat close
    SE Minnesota
    2,526
    Take a look at this and see what you think.
    Height reduced to 36 in. Legs are 1-1/4 in. square. Slats are 1/4 in. thick by 1 in. wide on 1-7/8 in. centers. Top aprons are 4 in. high. Stretchers are 2 in. high with a 1 in. high arc.
    May 2009
    Lafayette, Indiana
    2,380
    Wow Dave that was fast!. Looks pretty close to what I want. The only thing that keeps drawing my eye is the bottom stretcher. It's 2". Can that be taller? Or would that not look right?
    EDIT. Actually the more I look at it is fine the way it is.
  1. New design
    By Jeff Horton in forum Designs, Plans and Sketches
    Last Post: 02-07-2010, 04:52 AM
  2. I need some design help please.........
    By Ken Fitzgerald in forum Designs, Plans and Sketches
    Last Post: 09-28-2009, 01:21 AM
  3. design ,,when is to much
    By larry merlau in forum Designs, Plans and Sketches
    Last Post: 05-31-2009, 02:55 AM
  4. Need a little design help
    By Leo Voisine in forum General Woodworking Q&A
    Last Post: 05-26-2009, 02:07 AM
  5. Help with Box Design.
    By Pete Simmons in forum General Woodworking Q&A
    Last Post: 03-13-2007, 10:31 PM
