Results 1 to 7 of 7
Thread: Media Stand / TV Gear project (video)
    London, Ontario
    3,383
    Media Stand / TV Gear cabinet
    (video link at the bottom)
    Here is the "before" photo:
    About thirty years ago, my dad built this simple plywood cabinet for me to hold my stereo when I went to college. Since then it has served many purposes: stereo stand, bookcase, junk holder, TV stand, etc...
    But it was time for something else. I wanted something taller, narrower, with room for all our gear, and maybe still some room for drawers.
    Here’s the source wood:
    Everyone hates the word “reclaimed” these days, so I won’t use it. A few months ago we salvaged this solid wood table on trash day in our neighbourhood. It is likely an Ikea table, but that is just a guess. The top was solid pine -- laminated strips. The legs and understructure were painted hardwood.
    I was pretty sure that the I could build this stand from the pine table top -- or at least build most of it.
    After some work in Sketchup, I got busy ripping out the panels I needed:
    I then planed them to get rid of the finish and more importantly, get rid of the stains and dings in the old top. Fortunately it was over an inch thick. Unfortunately my side panels were too wide for my planer, so I had to rip them in half first and then re-glue them together afterwards.
    I was keeping things quick and simple, so I went with pocket holes for the assembly.
    As a side note, if you do use pocket hole joinery, then I highly recommend that you get one of these clamps. It is known as a right-angle clamp. I had a pocket hole jig for many years before buying this, and yes you can just use regular clamps. However this clamp is much quicker and makes the process just easier.
    Here I’m screwing hardwood runners in the cabinet for the drawers to ride on:
    I also assembled the drawers with pocket holes. This is so quick and easy, and the resulting holes are hidden by the drawer front. The rear holes face the inside of the cabinet so you never see any of them.
    I ripped dados in the sides of the drawers, to run on those runners noted above:
    Test-fitting one of the drawers
    This is a fairly plain cabinet, which is fine, but I wanted to add a little touch of something to the drawer fronts, and not just have flat faced drawers.
    I wanted to add a bead along the top and bottom edge of the drawer, but I don't have the right router bit. So I looked through my bits and was pretty sure I could get something similar with two operations, first using a small roundover bit, and then using a Small Drawer Lock Bit.
    (I did this on test pieces first) The roundover bit gives the curve along the edge of the drawer, and the small drawer lock bit cuts the groove.
    Here is a closeup of the resulting bead. I think it turned out pretty good, and it really makes the front of the drawers look better.
    With the drawer finished I could now put on the back of the cabinet. It is just behind the drawers, not behind the upper shelves
    I then wiped on a coat of shellac, followed by 3 coats of Varathane (Polyurethane)
    Finished Project, installed in our basement playroom
    More details are on my website: http://www.wordsnwood.com/2014/tv-gear-stand/
    Or you can watch a video of the process:
    What a great difference. Thanks for posting all the progress shots Art.
    5,167
    Wow! What a great idea. And I love re-purposing! I even have a donor table stashed away. Also, thank for the photos. I can't do videos. Your pictures really informed your post to be really inspiring and informative. And cool how you used two router bits to get the desire effect without buying a new bit. Love that philosophy as well. Came out really well. What will the old cabinet become?
    London, Ontario
    3,383
    Thanks, Carol! (Actually I forgot that I hadn't posted this when I finished it two weeks ago...)
    And I'm afraid that the old cabinet went out on the street. I loved my dad, but it was particle core, which I hate working with so I did not really feel like cutting it up for the plywood.
    30,008
    Nice job, Art. Thanks for documenting and sharing the process.
    May 2009
    Lafayette, Indiana
    2,380
    Nice job Art. You made it look very easy. Wish I could work that fast!
    London, Ontario
    3,383
    Quote Originally Posted by Tom Baugues View Post
    I dialed it up to three...
    (seriously, I watched another youtuber comment that he tracks his youtube stats and viewership drops off when videos go over 5 minutes in length. So I worked hard to try and compress things down.)
  1. knockdown guitar stand in cherry - (video)
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 05-30-2015, 09:05 PM
  2. Project Build: Narrow Office Side Table (video)
    Last Post: 12-09-2014, 02:12 PM
  3. new social media
    Last Post: 04-08-2013, 01:40 PM
  4. Umbrella Stand: Behind the Door, quick weekend project
    Last Post: 02-07-2013, 05:53 PM
  5. social media
    By Michael Hult in forum General Woodworking Q&A
    Last Post: 06-22-2012, 10:50 PM
