Results 1 to 10 of 10
Thread: Paduak bangle
    5,533
    Paduak bangle
    Today's the last day for banglebowl 2014; a fun contest dreamed up by Zac Higgins & Kyle Toth. Zac & Kyle are two new friends whom I met through Twitter. They got Marc Spagnuolo to host the contest on the Wood whisperer site. At last count there were nearly 40 entries in both turned and non-turned categories.
    I cut & glued up two rings of 8 segments each, which I then glued to a waste block.
ID:	86706 I also glued up two others, one in walnut , another in cherry.
    I used my face plate to hold the waste block, rounded the outside over & hogged out most of the interior. Following that, I parted it off from the waste block.
    I then reversed the ring on the scroll Chuck, and removed more material from the center . I used my bowl gouge, as well as my new scraper. The bangle is about 1/8 inch thick.
    I need to sand it down a bit more, then I will put a couple of coats of rattle can lacquer on it, take photos of it and submit it to the contest. Thanks for looking!
    Ned
    Attached Thumbnails Attached Thumbnails ImageUploadedByTapatalk1413982915.775136.jpg
    -Ned
    Austin, Texas
    1,448
    I have made a number of these, but never thought of using a waste block - great idea. Key to strength is to be sure the joints are staggered in the multiple layers.
    My biggest problem is the durability of the finish... they get dinged a lot on the wearer's arm (at least my wife's).
    Charlie Plesums, Austin Texas
    S E Washington State
    3,777
    looks like another fun woodworking project. Thanks for posting the how it is done!
    "We the People ......"
    3,132
    Ned that looks like a neat little project. Good job man.
    Jul 2007
    DSM, IA
    5,719
    Yet another project I need to give a try..looks great Ned!
    My Website
    Thomasville, GA
    5,992
    Looks great, Ned! Thanks for posting.
    Bill Arnold
    5,533
    Quote Originally Posted by Charlie Plesums View Post
    Well, so far I've only done three, first two got simple paste wax... easily renewed. Third one got a couple of coats of Watco natural. Both are easily renewed. I got the hint for the waste block from various youtube how to videos. Particularly this one by Kyle Toth:
    Quote Originally Posted by Paul Douglass View Post
    I would say 'quick' but it does take a day or two counting time for the glue ups to dry. Fun project though, and if you've made a turned box, it is very similar to hollowing out one of those! Thanks, glad you enjoyed it!
    Quote Originally Posted by Stephen Bellinger View Post
    Thanks Steve! I've had a bunch of fun making these for the contest (first one, this one plus a couple more in process.
    You'll get addicted in a hurry Jeff, they're reallllllly simple to do, and don't take a lot of wood at all.
    Thanks Bill!
    Oh, and here are the photos for the contest... Click image for larger version.
ID:	86713Click image for larger version.
ID:	86714Click image for larger version.
Name:	paduak detail.jpg
ID:	86715Click image for larger version.
Name:	pb main2.jpg
    -Ned
    Yorktown, Virginia
    5,014
    Really neat , Ned. The process doesn't look too complicated so that's something I might try. Thanks for sharing
    Oct 2007
    Schenectady, NY
    912
    Outstanding work Ned!
    Don Orr
    Woodturners make the World go ROUND
    5,533
    Paduak bangle
    Ted, easy enough! If you've turned a box , this very similar on the lathe.
    Here's another I turned yesterday: cherry , just a smidge smaller . Watco natural on it. A bit thinner, rang like a bell when I was turning it.
    Thanks Don! Having a ball out there!!
    Ned
    -Ned
  1. Cherry & Paduak Flag Cases
    By Karl Laustrup in forum Flatwork Project Showcase
    Last Post: 07-21-2013, 02:45 PM
  2. Barry's Bangle Tutorial
    By Vaughn McMillan in forum General Woodturning Q&A
    Last Post: 10-11-2007, 03:45 PM
