Results 1 to 4 of 4
Thread: Drill Press Table
    13,448
    Drill Press Table
    I started on building a DP table yesterday. I ended up laminating three pieces of 1/2" baltic birch. I'll be banding the side and front edges with some maple, the fence is cut out of some 8/4 cherry scrap.
Name:	2014-10-25 16.01.30.jpg
    The rear has a radius around the post, the cut out on the right is to allow for the elevation handle's swing.
Name:	2014-10-25 16.01.37.jpg
    I still need to add the banding and cut out a recess/sacrificial plate. I cut out a 3" recess in the fence to allow extra clearance.
Name:	2014-10-26 18.48.40.jpg
    Another view around the post and the recess for the chuck.
Name:	2014-10-26 18.48.52.jpg
    One small issue though, will have to cut down the height of the fence or have an auxiliary shorter one to use in it's place, which should be easy enough to swap out. The chuck is about 2" from the table at this point, so removing some height on the fence should work fine.
Name:	2014-10-26 18.50.12.jpg
    I have three different fences, one low profile for just this issue. The problem exhibits itself so seldom that I would not modify you current fence for it. I normally use a 3" tall fence but, have a 2" tall and a 1/2" (yes, half inch) tall aluminum extrusion (the original Woodpecker fence) as well. Another benefit of the split fence is that you can have a tall side on the left and a low side on the right for clearance. I made a few different fence faces for dad to meet his needs.
    12,256
    Cool following along. Something i need to get to soon for my new dp.
    13,448
    Finished up the outer trim tonight.
Name:	2014-10-27 20.32.43.jpg
ID:	86826Click image for larger version.
Name:	2014-10-27 20.32.51.jpg
    I had to take the front one off as it occurred to me that I wouldn't have any way to clean-out the t-slots, so cut some slots in it.
Name:	2014-10-27 20.31.11.jpg
    Here's a better pic of the fence opening. going to put a reinforcing piece of aluminum under the fence
Name:	2014-10-27 20.31.27.jpg
    I have 4 hanger bolts in the bottom, it's bolted to the DP's fence.
    Still need to cut in a hole for a sacrificial plate, will also seal the whole thing.
  1. Drill press table
    By Roger Tulk in forum Jigs and Fixtures
    Last Post: 05-01-2013, 08:52 AM
  2. Drill press table
    Last Post: 01-16-2012, 05:58 AM
  3. Drill Press Table
    By Roy Bauman in forum Jigs and Fixtures
    Last Post: 08-19-2011, 06:04 AM
  4. Drill Press Table Add-on
    Last Post: 09-10-2009, 09:48 AM
  5. Drill press table???
    By Chuck Beland in forum General Woodworking Q&A
    Last Post: 02-16-2008, 06:42 PM
