Results 1 to 3 of 3
Thread: Engraved brass plate
    Austin, Texas
    1,448
    I often make saddle stands, which have often had an inlaid Texas Map. But the requests for what goes on the map have grown from a few initials to things that would be candidate for laser engraving.
    My local source of laser wood engraving cannot engrave brass, much less cut it out in the shape of a Texas map.
    Is laser cutting of thin brass, accompanied by laser engraving, a high-tech expensive process, or are there sources where I could have it done at modest cost? I am looking for a map cutout that would be about 5-6 inches wide, and probably about the same height (I have to go measure Texas to confirm).
    Charlie Plesums, Austin Texas
    Melbourne, FL
    472
    CO2 Lasers cannot cut brass. I believe YaG lasers can but they cost even bigger $$$ than the CO2 lasers. Not many shops have YaG lasers.
    CO2 lasers are in the $8,000 - $25,000 range while YaG lasers are in the $30,000- $75,000 range.
    Of course exceptions to these prices can be found but these give you some idea while not many small shops have a Yag laser.
    East Freeetown, Massachusetts
    3,022
    I know someone that can do whatever it is that you want at a cost that is reasonable.
    I don't want to be soliciting here.
    If you sent me a PM with what you want - I may be able to direct you into something.
  1. Hand Engraved Planes
    By Layne Zuelke in forum Neander Tool Questions and Show & Tell
    Last Post: 09-01-2011, 03:36 AM
  2. chuck plate/face plate
    Last Post: 10-27-2009, 05:17 PM
  3. Gluing brass to brass
    By Larry Browning in forum General Woodworking Q&A
    Last Post: 12-07-2008, 12:33 AM
