Results 1 to 7 of 7
Thread: Router collet extensions
    Oct 2008
    1,357
    How safe are the 1/2" shank extensions? I have a bowl bit that I would like to try but it has such a short shank on it.
    Aloha,
    Aug 2014
    St. Mary's, Georgia
    398
    Need to see a picture of what you are doing
    https://www.facebook.com/BgCouger
    If you are going to make something nice, make it with a statement, use quality an do it right the first time
    Most bowl bits I have seen are quite short, designed with a bearing to be used with a template and the cutting depth is about 1/2". I have an extension that I believe came from MLCS. The quality is not great but, I have seen others of varying prices and the quality is about the same. I have used mine successfully for depths of about an inch. I did use a large plate as recommended and could see things getting squirrely really fast if you did not have one. That is, if the motor were to tip but, this is true with any larger or longer bit when doing handheld work.
    The good news is that you can do the work on a router table with greater safety IMHO. The principle is the same but, without the danger of tipping or overrunning your support surface if the bowl is quite large. The bulk of the waste is removed by forstner bit. The waste cannot be removed to full depth prior to the router bit since the center spur cuts deeper than the outer rim of the forstner. So, even when fully prepared, you still need to remove a fat 1/4" of surface for the whole area of the bowl plus the edges.
    I have a 1-1/4" and a 3/4" bowl bit. The smaller bit works well for smaller "dishes" and you can see I did not use the larger plate for these small openings. Hope this helps.
ID:	86868Click image for larger version.
    new york city burbs
    10,188
    Ive used the extension with the bowl bit a few times. As glenn said, using a oversized plate helps to avoid any tipping over.
    My first time I made this bowl/dish with the extension without any problems.
    I hogged out most of the inside with a forstner bit, then just ran the bowl bit over the rest.
    Human Test Dummy
    Aug 2014
    St. Mary's, Georgia
    398
    Thank you , I can see what you are talking about .
    Oct 2008
    1,357
    Thanks guys... I'll do a shallow candy dish the first go around to get the feel. I wanted to make deeper one to hold a little more... I'll watch the sales and maybe pick one up down the road.
    @Allen, I seem to remember when you bought that dish template... about 5 years ago I think. I was looking at them on Amazon today.....
    Aloha,
    new york city burbs
    10,188
    yeah, the last few dishes I made couple years back I just free handed a design and cut it out of Masonite.
    I did a snowman candy dish.cant find the picture files of that stuff, have a feeling its on my old computer somewhere.
    Now Id just rather spin something on the lathe, takes a lot less time if its only a 1.5-2 inch depth.
    Human Test Dummy
  1. Collet Extender
    Last Post: 08-04-2010, 02:28 PM
  2. Collet issue
    By Tony Maio in forum General Woodworking Q&A
    Last Post: 07-27-2009, 11:48 AM
  3. Another bed extensions
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 01-21-2008, 07:02 PM
  4. Bed Extensions
    Last Post: 01-14-2008, 07:13 PM
  5. Expanding Collet Chuck ??
    By Jeff Bower in forum New Tools
    Last Post: 12-06-2007, 10:27 PM
