Results 1 to 10 of 13
Thread: Grizzly 555LX and Carter Stabilzer
    Not sure where I should ask this so I will start here...
    I have a Grizzly 555LX 14" bandsaw. I enjoy making bandsaw boxs so I make a lot of tight corner cuts in 4" thick wood. I was using a Timberwolf 1/8" 14TPI blade. It is very hard to get the tracking right with the crowned wheels on the bandsaw. When I added the Carter Stabilzer in an attempt to get a better cut, I had a heck of a time keeping the 1/8" blade on the wheel. Carter suggests moving the blade farther back on the wheel and then adding the 1/8" of tension using the stabilzer. As soon as I add the tension with the stabilzer the blade goes all the way across the wheel and off. I had to add blade tension on the saw and move the blade all the way to the back of the wheels. I did this in fine increments until the blade stayed on the wheel. Needles to say the blade broke after a few cuts.
    Anyone have any tips? I need the 1/8" blade to make tight curves. Should I just forget about the Carter Stabilzer. Anyone have any experience with bandsaw boxes and 1/8" blades?
    Thank you in advance.
    Thomasville, GA
    5,992
    I added a Carter stabilizer to my G0555 earlier this year. I get very tight turns using a 3/16", 4tpi Carter blade. I bought the stabilizer and several blades from Carter at The Woodworking Shows in Tampa. I bought 1/8", 3/16" and 1/4" blades to have on hand but the rep at the show suggested using the 3/16" for best results. I've had no issue with tracking using the 3/16" blade.
    Bill Arnold
    13,437
    I've had a bad weld cause a blade to track poorly, have you tried another blade? Came across this video for setup on those guides...
    Yeap seen that video. I was thinking of trying a 3/16 blade. Not sure I will be able to make tight enough turns. I might be running up against a limitation of the saw with the stabilizer on it. The 1/8 blade didn't work too bad, I was just trying to get a little bit better.
    13,437
    I'd try another blade. Also, aren't the Timberwolf blades guaranteed?
    11,825
    To me, the use of a 1/8" blade on 4" thick wood would be exceeding the blades capabilities. Other might correct me, but that tiny blade just does not have the stability of a wider one. I can't offer suggestions on how to get a tight corner on wood that thick but I would look at other options, or designs for the project at hand.
    Going to Woodcrafters in Lenexa over lunch. They have a Timberwolf 3/16 10 TPI blade I am going to try. They also offer a 90 warranty. Not sure if Timberwolf themselves offer anything. I haven't checked.
    I will put this bad boy to the test tonight and report back.
    Thomasville, GA
    5,992
    I think Frank is on track (no pun intended) about the 1/8" blade being to narrow for 4" stock. Looking back at your original post, you've been trying to use a 14tpi, 1/8" blade which would be a double-whammy against making turns.
    Here's a photo of a test cut I did after putting the Carter Stabilizer on my G0555. I glued two pieces of 2x stock together, so I had about 3.5" thickness. This was done with a 3/16", 4tpi blade.
    Bill Arnold
    11,825
    Yep. Methinks what he is trying is really a project for a heavy duty scroll saw.
    5,319
    For tight turns in thicker stock, you need a blade with fewer teeth. This one works well for me, using the Carter guide on a TaiChi 14" saw.
  1. carter stabliser
    Last Post: 04-23-2014, 04:15 PM
  2. Carter accurite bandsaw blades
    By Alan Bienlein in forum New Tools
    Last Post: 01-26-2010, 03:25 AM
  3. Carter Bandsaw Stabilizer
    By Jiggs Elphison in forum New Tools
    Last Post: 07-16-2009, 03:45 PM
  4. Interesting BS fence idea from Carter
    Last Post: 10-31-2008, 06:31 AM
  5. Carter quick release bandsaw tensioner?
    By Wes Billups in forum New Tools
    Last Post: 01-08-2008, 05:10 PM
Tags for this Thread
