Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
Thread: dowels or biscuits
    Jun 2010
    3,220
    dowels or biscuits
    So I need some advice:
    I'm gluing up some boards to make 10" wide book shelves. I tried a few boards without anything for alignment, and it worked okay, but not perfect. I have one of those self-centering doweling jigs that I've never used. Should I use that or should I bite the bullet and invest in a biscuit joiner? Not the lamello--I was thinking of the Porter Cable. I have 72 shelves to make.....or about 30' of built-in bookcases. One of the esteemed woodworkers on this forum once told me to ask myself what my 10-year plan is before buying power tools or machines. I anticipate lots of built-in cabinets in the 10 years to come. All comments welcome.
    AKA The Rookie
    Thomasville, GA
    5,992
    Technically, gluing boards together to make a wider panel is as strong as you need. Saying that, I've used a ton of biscuits over the years to help keep boards aligned when I glue them up. One of the first tools I added when I started making furniture was a DeWalt plate joiner and it's still a go-to item at times, although I'm tapering off of larger projects. Anytime I have to make up a panel from narrow boards, I grab my DW and a box of biscuits.
    Bill Arnold
    new york city burbs
    10,188
    make or buy some cauls.
    glueing up boards to 10 inches wide shouldn't be a problem without biscuits.
    carefully use the cauls and clamps and you should get beautiful glue ups.
    Human Test Dummy
    Austin, Texas
    1,448
    I agree with both Bill and Allen.
    When I was starting to build furniture gluing up panels terrified me; I got the Porter Cable biscuit cutter (the best for the money), and it gave me confidence to do a lot.
    As I gained confidence and experience, I use it less and less - it does not add strength to the joint, but does help with alignment. My current project is a large dining room table - each half roughly 4 x 4 feet, with five leaves each 4 x 2 feet. All from solid lumber, and I haven't use a biscuit yet. (Total 72 square feet)
    Charlie Plesums, Austin Texas
    Yorktown, Virginia
    5,009
    I have both a biscuit joiner and Festool Domino, but for that kind of glue up would probably just use cauls unless you are short on clamps.
    5,167
    Buy some cauls first, if you don't want to make them. In the long run, much less expensive and much more forgiving. I have had both the Porter Cable and now the DeWalt tool. Had a hard time getting rid of the Porter Cable. Piece of "I can't say that here." DeWalt tool rarely comes out of the case. A good set of cauls will make you a happy camper for the next ten years and beyond.
    12,247
    Hi Cynthia good to see you around and still doing wwing. I have just completed some panel glue ups although very short and i have the pc biscuit joiner and did not use it.
    Here is my view of the biscuit issue.
    I have yet to have cut and used a biscuit where the resultant fit has meant i obtain the alignment possible prior to biscuiting.
    So it really depends on what people think of as "alignment".
    I found there are at least two types of actual biscuits one seems to be cut from thin ply and another that seems to have been cut and compressed its surface more " open" pores that allow the wooden biscuit to swell when glue hits it.
    So my findings have been the slot cut by the biscuit cutter left quite a bit of slop meaning alignment was not what can be achieved with cauls pressing a board flat.
    There is no strength gain as boards used in a panel are usually cut with the grain and thus the resultant glue up is normally stronger than the wood itself.
    I still for some unknown logic use biscuits from time to time.
    Honolulu, Hawaii
    1,103
    Seeing as we are defining the merits of these plate joiners/biscuit cutters, Would you please, Carol, Charlie, Bill, could you expound on your feelings about using these tools, or not liking them for me? What were their faults and what were their good points?
    I can see the points made for using cauls, but I never have had any yet. I would appreciate all your input. Thanks much.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Honolulu, Hawaii
    1,103
    Thanks, Rob. We must have been typing at the same time. Your input is what I am looking for. I do also want to know what particular faults biscuit cutters have, and or have in common. Thank you all again.
    Yorktown, Virginia
    5,009
    If you are exploring joining methods and equipment with a view toward long term versatility, consider also the Domino. It essentially gives you a floating mortise and tennon that can be tight fitting or loose (machine adjustable laterally), as you choose. You don't have the slop and joint strength weakness inherent with biscuits and the range of available domino sizes beats the heck out of dowels. You can also make your own dominoes with a round over bit on the router table, giving you the option of exotic woods and visible joinery. A pricy option, but if you amortize it over your ten year plan, not so bad.
  1. Fixo biscuits
    By Mark E Smith in forum General Woodworking Q&A
    Last Post: 01-03-2015, 02:03 PM
  2. Dowels and Tenons
    By mike marvel in forum General Woodworking Q&A
    Last Post: 02-08-2014, 03:40 AM
  3. How much weight will biscuits joints hold?
    Last Post: 08-27-2013, 03:03 AM
  4. Burl Biscuits
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 12-22-2008, 04:03 AM
  5. I hate dowels...
    By Ralph Laughton in forum General Woodworking Q&A
    Last Post: 09-02-2007, 09:17 PM
