Results 1 to 10 of 16
Thread: using my scraps
    new york city burbs
    10,188
    using my scraps
    I know making a segmented bowl is way above my pay grade, and the more pieces you glue up, the better it will look.
    I want to see how a simple one goes first, Im still getting limited time and as frustrating as that is in itself, along with discomfort, I want to keep things flowing easily out there.
    Took whatever I had in shorts or narrow strips over 1.5 inches width.
    Used the incra mitre 5000 sled , made each cut 30 degrees so there is 6 sides.(12 would have been nicer, glue up will drive me batty)
    made each layer 1/2 inch less than layer on top of it.
    Using a 2 inch piece of maple as bottom.
    heres some quick shots, no glue, have to go get some.
    Got some new stuff this week.
    And citizen(along with the help of my jeweler) did the right thing when they couldn't fix my eco drive watch, and it just slipped past the warranty stage, they allowed me another watch under 250 dollars.
    I have a few watches, I needed one for when I work outside,one that I could easily see the numbers, I kinda liked the military style of this watch.(best of all, it was free and retails for 125 more than what I paid for the previous one)
    having a good day. heading over to bobs favorite bagel café for lunch shortly.
    3 hours in the shop is good enough for me today. as usual, as much as I like to bore everyone, heres some pics off my cell.
    *I usually save all those strips and shorts for cutting boards, but really? how many cutting boards do I need to give away free, it aint the money, its the time spent sanding them and oiling them. really? everyone I know has one of my cutting boards.
    time to give them bowls.Im hoping when I turn it, theres enough with 1.5 inches width to get the full circle, otherwise, back to the drawing board and I might actually have to do the math instead of winging it.
    Attached Thumbnails Attached Thumbnails scraps 001.jpg   scraps 002.jpg   scraps 003.jpg   scraps 004.jpg   scraps 006.jpg
    Human Test Dummy
    13,437
    Cool, So does the round disk go inside the bowl blank to steady it?
    Nice watch btw, Citizens are my favorites. My buddies used to give me crap about spending $250 or more on a watch, but other than my wedding ring, it's about the only jewelry I wear.
    new york city burbs
    10,188
    I intend to just glue it and clamp it to bottom ring
    Human Test Dummy
    Oct 2007
    Schenectady, NY
    912
    Looke like you're having a lot of fun with this turning thing. Just a point of information about you bowl layup. Having the end-to-end glue joints of each ring all in line as you show them is not the strongest way to assemble this blank. It is common to stagger those joints as you glue the rings together for increased strength and stability. Look around at other segmented turnings and you will see what I mean.
    Hope this helps.
    Don Orr
    Woodturners make the World go ROUND
    new york city burbs
    10,188
    yeah, I noticed too late, I would have had to made the pieces much wider than 1.5 inch.
    The rings are glued up, Ill press them together tomorrow, maybe start spinning it Monday, my next one will be a bit more well constructed.
    the pattern would have looked much better also if I staggered them, but the wood isn't wide enough, learning process.
    12 shorter pieces with 15 degree cuts would have been much better to stagger them.
    I start a blanket chest/coffee table/toy chest tomorrow or Monday, Ill be off the turning after this for quite a while.
    Human Test Dummy
    new york city burbs
    10,188
    glued up, a lot of glue, maybe way too much glue, and I tried to stagger a bit, but there wasn't enough width on the pieces so I just turned them each a bit for a better hold.
    Put them in my homemade press, 6 cut 2x4s and 6 clamps, with plywood distributing the pressure.
    was tough to get clamps in place with only 2 hands. could have used help.
    looks like catch heaven in that bowl, hope I don't destroy it the first 5 minutes.
    I drilled a 2 and 1/8th hole in bottom to expand the chuck in to mount on lathe.**
    I hope it holds together, my 36th anniversary is the 2nd next month, this bowl will be my wifes gift.
    **Im thinking if I continue in the future to make larger bowls like this, I might get some cheap bronze colored tin medallians to fit the 2 and 1/8 th hole from chuck and have the medallions engraved with my name on it, I can sharpie in a date. Just thinking about it, or a small wooden medallion.
    Human Test Dummy
    new york city burbs
    10,188
    TOTAL FAILURE
    my glue up was all wrong, walls were too narrow, I couldn't spin round and true. And that was that.
    I separated the top off, maybe Ill get a small little bowl out of it, at least the bottom maple piece.
    Carbide chisels are sharp. Sharp as razor blades.
    I thought I heard someone come in as I was working I looked up, no one. Went back to work, my left hand on tool rest, right hand holding chisel, as I turned to go back to work, I ran the blade of the chisel right across my finger and it slit it open nicely, almost with surgical precision.
    Deep, and tons of blood. Lovely. Ok, had enough today.
    yes, I take pics of everything.
    Attached Thumbnails Attached Thumbnails bowlgonebad 003.jpg   bowlgonebad 005.jpg   bowlgonebad 010.jpg   bowlgonebad 011.jpg   bowlgonebad 013.jpg
    Human Test Dummy
    Jul 2007
    DSM, IA
    5,719
    Allen, I've never attempted a segmented bowl not sure how glue ups should be done...but I think I remember more pieces and 22.5 degree angles??
    Hope the finger heals up quick and you can get back out there. At least you know the chisel is sharp!
    My Website
    30,008
    To echo Jeff, I think you now see why most segmenters go with more than six pieces of wood per ring. Looks like the bottom bowl part is going to work out nicely, though.
    Heal quickly, and always remember where the sharp parts are.
    Independence, Kentucky
    1,354
    I believe you need more segments and with shorter lengths than you have there Allen This will ley you have a thicker wall to work with,
  1. There's Money in Those Scraps
    Last Post: 09-25-2014, 04:10 PM
  2. Pen Blank Scraps........
    Last Post: 02-01-2010, 11:37 PM
  3. Another good use of scraps
    Last Post: 11-28-2009, 02:25 PM
  4. Using Up Some Scraps
    Last Post: 04-03-2008, 09:32 PM
  5. Save your Scraps!
    By Ed Nelson in forum Flatwork Project Showcase
    Last Post: 03-26-2007, 02:02 AM
