Results 1 to 10 of 12
Thread: More Turnings
    knoxville, TN
    41
    More Turnings
    Hope you like these. The open works has a spiral twist within a multible twist.
    The Top and stand are Ebony, Holly ang Pink Ivory.
    Attached Thumbnails Attached Thumbnails Gob.jpg   TOP.JPG   Ornament.jpg   Box.JPG
    Jerry....You are a true artisan! Fantastic turnings....I hope you'll share some of your techniques with us!
    knoxville, TN
    41
    The open twists are done by hand with a carbide grit round file, then perfected with finer grit paper wrapped around a drill bit of the correct size.
    The Pink Ivory Inlay in the Holly portion of the top is a fairly complicated procedure. It requires several generations of altered glue-ups and cutting and sanding before it can be put on the lathe.
    When I find some spare time I will put together some sort of document on the procedure.
    30,223
    Fellas, we have a segmented turner in our midst!
    You do very nice work, Jerry. You've obviously been doing this for a while, huh? Gad to have you here, and looking forward to learning some from you.
    15,811
    Wow Jerry, I can only imagine the work that went into those!
    Look forward to some documentation.
    11,899
    I don't know what #s 2 & 3 are but all items show outstanding craftmanship. Welcome.
    knoxville, TN
    41
    Platonic solid
    The second from the left is a spinning top sitting on its display stand.
    The third from the left is a Christmas tree Ornament made from Bloodwood
    and Holly.
    This new ornament below is called a Platonic solid with 96 vertices turned into a perfect ball. It is made of Makore and Walnut with rhinestones at each
    vertices.
    s. Barrington,IL.
    127
    Jerry all I can say is that is fantastic work I wish someday I could come close.
    Ken
    Northville, MI
    507
    Great works Jerry. I don't I have the patience for that type of work.
    Jim
    knoxville, TN
    41
    Thanks for the comments. I will try and post some step by step instructions for a project, I will wait an see if there is a concensis on which one to post.
  1. New turnings
    By Ted Tailor in forum Lathe Project Showcase
    Last Post: 06-28-2010, 05:14 AM
  2. a few more turnings
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 12-14-2009, 03:58 PM
  3. New turnings, *#8 and the LAST*
    By Barry Richardson in forum Lathe Project Showcase
    Last Post: 06-08-2009, 06:57 PM
  4. Some Turnings
    By Cody Colston in forum Lathe Project Showcase
    Last Post: 06-26-2008, 02:58 AM
  5. more turnings
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-08-2008, 01:13 AM
