Results 1 to 7 of 7
Thread: Stain Suggestions for Hickory?
    Jun 2010
    3,220
    I don't have a lot of experience with stains.
    I've finished the ash interior of my bookcases with Minwax Whitewash "pickling" stain on both plywood and wood. I like it. I can see the grain but it's very light.
    Now I'm using some hickory for the exterior trim, but it's so pretty and has so many different light and darks, I'd like to use something different to better see the variation in colors in the grain. Does anyone have any suggestions? Something not too dark that I could buy at the local big box store.
    Thank you
    AKA The Rookie
    What is your expected wear factor? Oil / varnish blend on pecan; a close cousin:
    The pecan sides of this box are just done with clear shellac:
Name:	Bevy of Boxes (15).jpg
ID:	87456Click image for larger version.
Name:	Bevy of Boxes (14).jpg
    Jun 2010
    3,220
    Thanks Glenn. Love the box! I think I'll forget a stain, and just go with a clear coat on top.
    AKA The Rookie
    Nov 2012
    Wapakoneta, OH
    611
    Quote Originally Posted by Cynthia White View Post
    Good plan, I find hickory so nice looking the grain and coloring is the star of the show. I'd use a lot more of it if it wasn't such a pain to mill.
    Apr 2009
    Outside the beltway
    5,250
    Cynthia, you can use the Minwax penetrating stain , after you wipe it on take a rag soaked with thinner , depending on how much you want to remove depends on the amount of thinner on the rag. Best to do a test area , Let the stain set about 5 minutes and then wipe off. Usually this will give you more of a grain look, wiping away the top wipes off the harder grain areas resalting in more grain
    Oak table with hickory wiped stain;
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Quote Originally Posted by fred hargis View Post
    Amen to that. I did two large pieces and had to send out literally EVERY cutter I used on them; router bits, saw blades, etc. The only things that survived in a usable state were the carbide inserts in the spiral heads and I'm sure their life was shortened as well ;-)
    Jun 2010
    3,220
    I agree about the milling. It's wearing on my blades. But it is sooooo pretty......
    AKA The Rookie
  1. Can we help Hickory?!!!!!!!!
    By Mack Cameron in forum Off Topic Discussion
    Last Post: 02-25-2012, 02:23 PM
  2. Hickory vase
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 09-03-2011, 01:59 AM
  3. hickory crotch hf
    Last Post: 09-15-2010, 09:42 AM
  4. Any suggestions on how to stain oak border around maple ply
    By allen levine in forum Finishing School
    Last Post: 05-09-2008, 11:33 PM
  5. Hickory HF
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 12-31-2007, 02:25 AM
