Results 1 to 2 of 2
Thread: Mitre Guide Sacrificial Fence
    I was wondering who else does this, the sacrificial part of my mitre fence gets chewed up, and shorter over time, I like to have a backing to prevent blow out on most cuts, so I make a few at one time when it is time.
    Mine are made from 18mm thick MDF cut 70mm tall and 450mm long, YMMV
    I counter sink a few holes for the bolts that hold them in place on the mitre guide, so I use the old piece to line up my fence on the drill press, then drill away.....
    I use the same set up to drill the hole for the bolt to go through, sometimes I put four holes in the piece, sometimes three.
    I then put a strip of PSA #240 sandpaper along the edges, this time I was running low on such sandpaper so I only did one edge on two of the pieces.
    You can see the chewed up piece there too. I then label them as Mitre Guide and stow them under the SawStop.
    Is there some other way to do these? This has worked for me, but I was thinking that the brain trust here might have some better method.
    Domo
    30,008
    I have the same miter gauge and also use a sacrificial fence on it. I made mine out of 1/2" or 5/8" BB ply years ago. (Don't remember for sure, and it's deep in storage right now.) It has gotten shorter, but not so short that I've needed to make a new one yet. Eventually I will, though. I didn't add any abrasives to it, and haven't really had a problem with slippage.
  1. Replies: 4
    Last Post: 07-08-2011, 04:34 AM
  2. New TS Fence w/Router Fence Attachement
    By scott spencer in forum New Tools
    Last Post: 05-21-2009, 08:31 PM
  3. SOLD: TABLE SAW FENCE - SHOP FOX CLASSIC (fence only)
    By scott spencer in forum Old Ads
    Last Post: 05-12-2009, 05:18 PM
  4. Sacrificial Table Saw Fence Clamps
    By Dan Gonzales in forum Jigs and Fixtures
    Last Post: 03-24-2009, 05:09 PM
  5. New mitre saw
    By Ad de Crom in forum Jigs and Fixtures
    Last Post: 09-24-2007, 09:12 PM
