fred hargis
- Wapakoneta, OH
Too much material going up in smoke being each stile would have to have two partitions behind it. Doing that also doubles the number of points to hit dead on for things to line up when setting your frame. The alignment issue could go away pretty easily if you don't dado everything together. Even if I've got a drawer opening where I could flush it out with the partition or ends, I don't bother for that reason. I just use build out for each drawer opening. If the carcass or the face frame is off a few thousandths in one way or another, it won't show, either the adjustment in the hinge is adequate, or the buildout for the drawer masks that failure. I also don't care for seeing the gap of the shelf to the partition/side head on when you open a door, and prefer having that visually behind the frame.
That's not my experience, there was just a gap between the carcase....no wasted material of any kind. Never had any alignment problems, either, since the only contact is the face frames. But, there's a 100 ways to build cabinets. They are all correct, just pick what you like.
