Results 1 to 10 of 15
Thread: Oh Bother--- electrical issue
    5,533
    Exclamation Oh Bother--- electrical issue
    Well, I tried to fire up my drum sander this morning. My shop used to run on extension cord out of our utility room. It doesn't at the moment, because I've evidently blown the entire circuit for the washer/dryer. I've reset the breaker, but to no success. Needless to say, Lori is far from happy with me at the moment & wants me to divert some of the Kickstarter funding to putting a meter and panel out in the shop itself.
    Ignoring the sub panel/meter discussion for the moment. (I'm all for it, just not sure if we can swing it before the new year.)
    What could I be missing on the breaker front? I've reset the entire panel, but no luck in the utility room. I don't have a meter or tester until I pick one up tomorrow. Any suggestions on what I'm Looking for today? I've unplugged the shop, so there's no load going out there, and the dryer works if I plug it in to another outlet. It has been at least 2 hours since the breaker popped. Suggestions?
    -Ned
    East Freeetown, Massachusetts
    3,021
    Maybe a loose connection somewhere. Maybe the white wire in the circuit box.
    It is entirely possible that the breaker is bad.
    Cedar Rapids, IA
    170
    I'd also suspect a bad breaker. If you have central air and the breaker is equal or less than the breaker for the dryer outlet, you could borrow that one for the short term. If it's of higher value, I wouldn't recommend it since you're already dealing with a potential dead short somewhere. When you bring the line back up, test it with a known good tool before trying the sander again. The wiring in the sander may have an issue.
    5,533
    I strongly suspect it was purely load that kicked the breaker. More later, I'm on the road for work .
    Ned
    -Ned
    13,361
    You don't happen to have a GFCI on that circuit do you? Maybe check to see if that is tripped as well?
    Nov 2014
    Central Illinois
    16
    Breakers have been known to die following an overload or two. I'd start there. Good luck...mad wife...been there!
    London, Ontario
    3,383
    Quote Originally Posted by Ned Bulken View Post
    Another outlet?? Is this a gas dryer or an electric dryer? I have a hard time picturing a house that has TWO electric dryer outlets.
    ie: is this a regular 110 outlet we are talking about? Is this the only outlet on that circuit? If so, it is also possible that the outlet itself is the problem, if you have been consistently drying a high load through it.
    As to the meter/panel -- couldn't you just put in a subpanel, no need for a meter!?
    ...As to the meter/panel -- couldn't you just put in a subpanel, no need for a meter!?
    I was thinking the same thing.
    13,452
    I'd also suspect a bad breaker. Also, how long is the cord run and what guage is it?
    Jul 2007
    DSM, IA
    5,719
    So Ned, did you get this worked out? Hope so...
    My Website
  1. Noob At Work, don't bother me with the facts
    By Mark Rice in forum Finishing School
    Last Post: 06-17-2011, 04:56 AM
  2. Not sure why we bother putting locks on doors...
    Last Post: 03-22-2010, 11:18 PM
  3. Why I bother to wear a dust mask.
    By Chas Jones in forum Turning Tool Questions and Show & Tell
    Last Post: 05-03-2009, 03:42 PM
  4. electrical fan ?
    Last Post: 09-04-2008, 04:28 PM
