Results 1 to 10 of 10
Thread: Bandsaw Blade ?
    Jun 2012
    Laurinburg NC
    319
    Bandsaw Blade ?
    Im sure this has been tossed around a bunch. I have an older 14" Delta Rockwell bandsaw with a riser kit in good shape and need some direction on a good bandsaw blade for prepping bowl blanks from mostly woods that we have here in NC
    Need favored brands, the tpi , width of the blade...And who has the best deal......this kind of stuff Thanks!!
    The most commonly-recommended blade for cutting turning blanks is the Timberwolf blade. It's a good blade, but personally, I think these are just as good if not better, and they are about 1/3 the price:
    Ellis Manufacturing, 1/2" 3 TPI "Flexback" listed toward the bottom of this page:
    http://www.ellissaw.com/Band-Saw-Bla...ade-stock-list
    For the record, I've used plenty of Timberwolf blades, as well as Olsen blades and the Woodslicer from Highland Hardware. (The Woodslicer is not intended for cutting turning blanks.) After using the Ellis blades, I have no idea why someone would waste money on the "name brand" blades.
    Also keep in mind that bandsaw blades are expendable, like sandpaper. Don't plan to just buy one blade and be set for life.
    Aug 2008
    Reno, Nv
    3,632
    ^ yup
    Austin, Texas
    1,448
    Most of my work is resawing - a different challenge. For my small (14" with riser) bandsaw, I have used Timberwolf blades, but would try the Ellis blades I have heard such good things about.
    If you use do Timberwolf be sure to get the blades tuned for cutting green wood - I believe (from memory only) the code is AS for alternate set.
    When Vaughan talks about expendable, think of an hour or two of use.
    Charlie Plesums, Austin Texas
    Thomasville, GA
    6,000
    +1 for Ellis. Call them, tell them want you want to do and they'll fix you up!
    Bill Arnold
    I have used Timberwolf blades and several other brands. The absolute best I have gotten to date have been the "woodturners" blades from Highland Hardware. They are especially made for green wood and bowl blanks. They are thicker at .032 and are 3/8" wide and have more set in the teeth than regular blades, for clearing the kerf of sawdust/chips. They have 3 tpi and are a bit aggressive, but with good technique and firm hold, they outshine others, making bowl blanks from logs, the best I have ever seen. Some folks really like the Lennox diemaster blades as well, as they hold up well.
    At Highland Hardware, you can order blades to length for what ever saw you have..........I highly recommend these blades.
    4,553
    Two words..............Call Ellis
    A Turn N Time
    Frog Pond Guitars
    Feb 2012
    2,749
    I would go with a " 3 - 5- tpi blade too. I have one with 5 tpi, and I think it's skip tooth. It's great for straight cutting. I get all my blades from a Canadian supplier called R&D bandsaws.
    Cheers,
    Roger
    Tellico Plains, Tennessee
    4,353
    I'm no expert, so take this with the usual grain of salt... I buy most of my blades from Packardwood... they're the Olson brand and at a good price... I know from the last session I had with bowl blank preps... you're going to go through blades pretty quickly and I remember someone on here posting that they had talked with Timberwolf or one of the other high named blades, that a blade is only good for a little over 200 board feet....
    I haven't tried the Ellis blades yet but probably should... might get a family discount ?
    Chuck
    Tellico Plains, TN
    Chuck, by switching to Ellis you'll pay half as much, and get a blade that's at least as good as the Olson.
  1. Bandsaw Blade Question
    Last Post: 12-10-2013, 07:08 PM
  2. Jumping bandsaw blade
    Last Post: 01-09-2010, 01:07 PM
  3. Bandsaw Blade
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 01-09-2010, 01:26 AM
  4. Bandsaw Blade Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 08-04-2007, 01:11 PM
  5. What bandsaw blade?
    By George Conklin in forum General Woodturning Q&A
    Last Post: 11-26-2006, 01:07 AM
