Results 1 to 8 of 8
Thread: Incra T-Rule - Stop
    Incra T-Rule - Stop
    I am not sure how useful anyone might find this but, I have run into situations where I wanted to use my 6" T-Rule but, it was too long (ran into an adjacent object). I made a very shallow dado in a piece of squared up scrap pecan, glued it to another identical piece of scrap without the dado, added a threaded insert and a crude knob made from a stack of nuts on a brass machine screw and I'm all set. Takes up little room and will help me out next time I find myself in that position.
Name:	Incra Rule Stop (1).jpg
ID:	87594 . Click image for larger version.
Name:	Incra Rule Stop (2).jpg
ID:	87595 . Click image for larger version.
Name:	Incra Rule Stop (3).jpg
    5,172
    Cool idea. Gave me another one for longer rulers using a nylon thumb screw. Got lots of those. I made u-shaped stops for the rulers but they slip. This won't. Thanks, Glenn. These help with the no brainer, no math layout issues, especially when clamping tracking for sawing. Two rulers, 2 stops, 2 spring clamps. No pencils, no numbers, no measuring (except for the initial measuring), no memory problems!
    Set the stops identically on each ruler. Spring clamp it to the edge of the panel. Lay the track against the ruler, clamp securely, remove the stops, and rip away!
    Measuring and numbers can get you into real trouble in woodworking!
    Catalunya
    4,632
    Hey Glenn, I understand that the threaded insert is to lock it in position, isn't it? Doesn't it risk to damage the thin edge of the ruler?
    Best regards,
    Toni
    Cool idea, Glenn.
    ...Measuring and numbers can get you into real trouble in woodworking!
    This bears repeating. To the extent possible, I'd rather either use a story stick or build everything to fit one or two key dimensions. Or just put all the rulers in a drawer and toss a piece of firewood on the ol' lathe. D
    4,699
    While I agree in principal these incra rules are really handy for doing parallel lines or specifically spaced holes or other similar uses. Especially for making templates :P As long as you don't move the stop it should be fine I actually have one without the T end that I got at an estate sale and a stop (or two) would be pretty hand for it.
    I do wonder about Toni's point and am assuming that Glenn thought of that part somehow...
    luckily you aren't biased
    I slightly domed the end of the soft brass screw. If I was a machinist I could have probably come up with a tiny swivel-pad or something. If I really laid into it I could definitely damage the edge of the rule, jam the screw or both. The slot is a snug fit so the rule stays put with just a slight snugging of the screw. I nylon knob/screw would work as well. I just happened to have the brass screw
    ...these incra rules are really handy for doing parallel lines or specifically spaced holes or other similar uses...
    I've got one of the 6" models, and love it. I may try to avoid having to measure stuff and mark, when when the need arises, the Incra is my go-to ruler.
    Apr 2008
    Independence MO
    561
    Seem's like the reason we used to have some of the hand tools, like a Stanley Odd Jobs. You could measure where you have no good way of using a story stick and then set the Odd Jobs as a story stick, itself.
  1. 3-4-5 Rule
    By Darren Wright in forum General Woodworking Q&A
    Last Post: 03-25-2013, 11:54 AM
  2. Arch rule
    By larry merlau in forum Jigs and Fixtures
    Last Post: 02-16-2013, 05:25 AM
  3. Incra Miter Gauge - Shop Made Stop
    Last Post: 07-14-2010, 01:08 PM
  4. Incra LS System & Incra Original Jig
    Last Post: 05-31-2009, 05:22 PM
