Results 1 to 9 of 9
Thread: milling a maple
    Oliver Springs, TN
    1,726
    milling a maple
    Started a little milling today with Lucas. This is a 8' x 27" red maple that I've had in my spalting pile for around 2 years. This is a side shot after we knocked most of the bark off Click image for larger version.
ID:	87732, and here's an end shot. Click image for larger version.
ID:	87733Click image for larger version.
ID:	87734 You can see the middle had started to rot when it was standing. Here's a couple of shots of some of the goodness that was inside. Click image for larger version.
ID:	87735Click image for larger version.
ID:	87736 I cut a slab 3" that I'll process into turning blanks. One side of the slab had some white rot started. That's the scourge for spalting wood it gets punky quick. Here's one that causes white rot, turkey tail fungus.Click image for larger version.
    May 2011
    Cape Cod, Ma.
    1,553
    Wow! Going to get some beautiful stock out of that one!
    13,360
    Wow! That's really cool John. Jsut curious, is there something special about where your spalting pile is that helps to encourage spalting to occur? Or does it just happen?
    Yorktown, Virginia
    5,011
    That spalted nicely and I think you caught it just in time. Nice looking mill too.
    Oliver Springs, TN
    1,726
    I'd like to be able to say that I have a top secret one of a kind spalting location, but alas it just happens! Mine is at the edge of the woods in a shaded low spot that stays damp. I have taken plane jane maple cut in 2x2 blocks before and used jointer shavings from a spalted board in a garbage bag and spalted them in around 6 months. I'd check on them every month or so and sprinkle some water in the bag to keep the moisture up.
    Thanks Ted, it's fun milling and the mill has been a workhorse.
    Jan 2011
    3,798
ID:	87740 Beautiful!
    Oliver Springs, TN
    1,726
    I found this in a piece I resawed today.
    new york city burbs
    10,188
    with all the spalted maple I purchased, I noticed most of the finest looking spalting is located at the ends of each piece, not as much in the center.
    Im guessing the fungus works its way in from the ends?
    Human Test Dummy
    Oliver Springs, TN
    1,726
    I've noticed that too Allen. The best spalt I usually get is from the ends and about the first 2-3 inches inside the log. I've cut the ends off and the first few inches off the log and put it back in the spalt pile before so it could do some more spalting. This log has been down for probably close to 3 years and the center is as solid as the day I cut it, except for the hollow spot. It takes a lot longer for logs to rot than I thought!
  1. Milling an Oak
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 11-18-2014, 02:08 AM
  2. results of milling a spalted sugar maple
    By John Daugherty in forum General Woodworking Q&A
    Last Post: 12-24-2012, 06:10 PM
  3. milling a sugar maple
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 10-22-2011, 04:54 PM
  4. Milling Around
    By Don Orr in forum Lathe Project Showcase
    Last Post: 03-05-2010, 05:08 AM
  5. How much time after milling?
    By Rob Bodenschatz in forum General Woodworking Q&A
    Last Post: 07-19-2007, 02:08 PM
Tags for this Thread
