Results 1 to 2 of 2
Thread: Edge Sander Fence Modification
    I have often been sorry I sent my vertical belt sander down the road (there's only so much room in my shop). I really miss it for things like the edges of end-grain cutting boards as sanding the vertical grain horizontally or circularly just leaves more work later. There is a cast "fence" that came with my Jet edge sander that has never been much use. although I can't get the belt path to be vertical, I can orient myself to get the same function. I just needed a more substantial fence. I laminated a couple pieces of scrap 3/4" ply together and milled out the areas that required clearance:
Name:	Edge Sander Fence Mod (1).jpg
    I attach the ply to the cast fence, set the sander to this position and add the fence via the supplied knob:
Name:	Edge Sander Fence Mod (2).jpg
ID:	87785 . Click image for larger version.
Name:	Edge Sander Fence Mod (4).jpg
    Now I have something like this:
Name:	Edge Sander Fence Mod (3).jpg
    This piece of cherry is just for example and the grain is not running in the direction I would use this attachment for:
Name:	Edge Sander Fence Mod (5).jpg
    Imagine an end grain cutting board with a curved outer edge with the grain running vertically:
Name:	Cuttboard and Trivet (5).jpg
    This will allow me to rough sand those surfaces without leaving a bunch of sanding marks that take an extra effort to remove later. It will have to do since I can't shoe-horn one of these in the shop:
    In my dream shop all of my sanding stations are along one wall ;-)
    12,243
    You sure got me thinking Mr Bradley. I cant fit anymore into the place i am in right now but in the future thats going to change and then a sander will be on the cards. Clever move Glenn. I learn a ton from your posts never considered the grain issue when using a sanding machine.
  1. Ridgid sander modification
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 03-29-2014, 12:59 PM
  2. Homemade edge sander
    Last Post: 07-08-2010, 10:45 AM
  3. Interesting SCMI edge sander
    By John Rutter in forum New Tools
    Last Post: 10-13-2008, 03:45 AM
  4. WTB:Edge Sander in Houston,Tx
    By Carroll James Courtney in forum Old Ads
    Last Post: 07-04-2008, 06:47 PM
  5. Edge sander
    By Paul B Cresti in forum New Tools
    Last Post: 12-04-2006, 01:01 AM
