Results 1 to 9 of 9
Thread: Purple heart wood
    Nov 2014
    florida/tennessee
    28
    Purple heart wood
    Got some purple heart wood coming today, never used before do I need to use anything special with it ? Glue? Dust?
    Dennis
    https://www.facebook.com/oldyankeeworkshop
    Check my facebook page and like it please
    5,167
    It is hard and tends to splinter easily. No special glue. Some folks are hyper sensitive to the dust but dust protection for any wood is always a good idea. Splinters in the fingers tend to get a reaction that can fester quickly. Very sharp tools for smooth cuts and good joinery are the order of the day. Also, don't expect it to stay purple. Exposure to sunlight will turn it brown. It is heavy which might affect your application. What did you plan to make with it?
    Nov 2014
    florida/tennessee
    28
    plan to make few of these thing for xmas gifts...it will be used as center strip...Click image for larger version.
ID:	87819Click image for larger version.
    Dennis
    Jun 2010
    3,220
    What Carol said +1. It's hard like concrete. I've used a little in a couple of projects and hated working with it. Hard to sand, hard to plane, etc. etc. but beautiful stuff.
    AKA The Rookie
    5,167
    As a center strip that will work well. Plan to turn the circle? That will be the easiest to get it all smooth. Purple heart is a bear with hand tools. And it will turn like concrete as well. Sharp, sharp tools. The surrounding wood will be much more easily worked, so be mindful of that to keep things flat across the surface.
    To elaborate on Carol's words; it is easy to get a rippled or irregular surface when you power-sand mixed materials that have a wide range of hardness. Just use a cork, felt or even a wood block and you'll be fine. If you have never had the experience of taking after something with a ROS only to end up with a surface that looks like wind-blown sand dunes, you haven't lived
    Jun 2010
    3,220
    ... only to end up with a surface that looks like wind-blown sand dunes, you haven't lived
    yup. BTDT. Click image for larger version.
    AKA The Rookie
    Tellico Plains, Tennessee
    4,351
    I like purpleheart... I use it mostly in pepper mills and wine glass stems.... it does have a bit of a rough grain, so sharp tools if turning.... it will dull them quickly, so sharpen often... it sands okay, but will be rough... I've never gotten PH really really smooth in sanding.... also as said, watch the splinters. It will work up brown, but exposure to light will let it turn back purple.... I forget the word for it, but the wood is photo ---- something or other--- then over time it will brown out again, but usually takes a few years...
    Chuck
    Tellico Plains, TN
    Nov 2014
    florida/tennessee
    28
    I'll see how this stuff works next week going to glue it up and cut it out, then use my shaper or router to get it right.
    Dennis
  1. Another Purple Heart Question
    By Kevin Sadaj in forum General Woodworking Q&A
    Last Post: 11-22-2014, 11:05 PM
  2. Dangers of Purple Heart Wood?
    Last Post: 11-12-2014, 06:04 PM
  3. Purple Sierra with Purple Gel Refill
    By James Lord in forum Lathe Project Showcase
    Last Post: 09-27-2011, 11:34 PM
  4. Purple Heart
    By Les Hoste in forum General Woodworking Q&A
    Last Post: 12-04-2009, 01:02 AM
  5. ammonia fuming purple heart UPDATE
    By John Daugherty in forum Finishing School
    Last Post: 07-15-2009, 09:09 PM
