Jason Beam
- Sacramento, CA
Oh alright, here's the one that leaked early ... lol
You mention it being rosewood isnt that very black for rosewood? Looks more like ebony to me.
Question i have and was thinking is could you not have used your cnc to cut that pearl plastic given you already have those cut outs programmed if you cut them with an offset to the cut out size and then sqaured them up with your sanding setup.
Would think the starting edges would be straighter than scroll sawing tiny bits.
Its always easy to spot mistakes when one is looking over someones shoulder versus actually doing the work. Good recovery. Other thing is how else could would you have done that. From where i am i was thing something was needed to hold the outer pieces in place as u clamp. And u can always cut another mold on cnc so no harm done really.
While i am at it i have been wondering do u plan on ever making more than one of these guitars? Kind of make a few more to recover some cost u put into it all?
Surely there would be a market for them given how close u are trying to be to period guitar. ?
As you were applying vacuum to glue the front and back on, I couldn't help but wonder why the outside air pressure didn't crack one or the other.
BTW, I absolutely love this series. You're doing really well!
Coming along nicely. I was screaming at the video as you were gluing the front side on..."How are you going to get the mould off!!!". Sorry you couldn't hear me. Nice recovery(s) though.
As I watched this and thought about Ted's comment on jigs (which is right on the mark), it occurs to me that we're seeing only the end product of an awful lot of thought and planning. Everything, well, mostly everything, seems to go very smoothly, but that happens only when there's been a lot of previous thought and rehearsal of the process. Do you have any idea of how long, how much time you put into this build before you actually started?
Another good video Jason.
I have some questions/comments though.
How come u did not get tear out routing through your templates with the templates not being in contact with the surface?
I was expecting u to lay down some blue tape to protect tge surface.
Then when u were routing the edge you mentioned doing it in multiple passes and i was expecting you would use a oversize bearing for the initial pass but you described a full normal 3/4 flush trim bit.
I was shuddering as you cut those edges how did you control not taking off too much in one go.
I guess the one think thats impossible to convey in a video is the feel.
Thats a cool jig that holds the router for the edge routing.
Now my knowledge of guitars is absolute zero so please take this as a comment from an utter idiot on the subject.
I find it hard to believe or grasp/accept that the neck is going to attach to the body with only that small mortise to secure it and yet stand up to i presume the guitar being able to be picked up by the neck with that joint supporting all the disproportionate weight of the body attached.
So doew one need to be gentle with this guitar assembly after complete?
I guess i am also thinking that when strung over the human neck i presume both sides of the strap hook up to the body ?
Dunno it just seems mechanically suspect , but then i am an "if in doubt build it stout kind of character".
Would like to see some still close up shots of the edge joints now they cleaned up just to see how well the mating of that but joint between side and top went.
I recognise you building this period correct however part of me wanted to see that joint being a rabbet cut by cnc into the top underside for the edge to ride in. Lol.
