Results 1 to 9 of 9
Thread: Hanger Bolt ..turned leg question.
    12,256
    Help... please need some advice on hanger bolt length.
    I am in the process of setting up to make my own 4 inch diameter 4.5" high turned legs from maple that will be attached to the bottom of our couches to raise them higher.
    Something like this but no flutes.
    http://www.lowes.ca/table-leg-hardwa..._g1201593.html
    will be using leg plates http://www.leevalley.com/en/hardware...=3,43586,43590
    to attach to couch.
    Now my question is how long should i make my hanger bolt ?
    I have various lengths in my hardware stock.
    5,321
    Rob,
    Wait until you actually get the leg plates, then cut the hanger bolt to the right length.
    12,256
    My bad, thanks for your reply Jim but once again i was not clear on my question.
    I am actually wanting to know how long i should have the screw part screwed into the wood.
    Example in the same thickness 5/16 i have 1.5" length bolt where screw thread is 7/8 of hat 1.5"
    then i have 3" long 5/16" bolts where the screw thread (not machine thread) is 1 and 3/8" long.
    Will have to cut the machine threaded end on both but wondering which to choose to use?
    Hope this is clearer. Leg height is going to be around 4.5 "
    The strength of this whole combo is really how well the nut is secured in the leg plate and i have them on hand already.
    BTW if anyone ever wants to use these , get the lee valley ones they way better than lowes, cheaper and thicker plate with extra hole not that its needed in my application but every screw counts.
    5,172
    Agree with Jim. Have parts in hand before making any decision.
    That said. Rule of thumb for fasteners is 1.5 times the thickness of the piece being fastened penetration into the piece doing the holding.
    However, when it is a metal plate, that rule is silly. I would however penetrate a distance of 2/3's the available thickness of the holding piece. My rule of thumb for that application.
    But also depends on angle of stress. Is leverage type stress expected? Or is it sheer stress only? Leverage asks for more penetration. Sheer for larger diameter of the fastener.
    I did not look up your fastener so I am answering by way of general application, much as an instructor would, leaving it to you to think about what you want to do.
    So, thanks for letting me shine some light and stir up some obfuscation.
    5,321
    Use the longer one, Rob, and sink it full depth.
    I assume you know how to install them, using two nuts jammed together?
    12,256
    Thank you Carol and Jim, thats what i was going to do following the "if in doubt" principle. Thought i might check first though.
    I gotta say i am in doubt about how well this connection will take the visiting lineman when he comes home and flops on the couch. Then he might just get
    Yorktown, Virginia
    5,015
    ....I gotta say i am in doubt about how well this connection will take the visiting lineman when he comes home and flops on the couch.....
    When I first got married I built our couch, using rubber webbing straps and clips, those anchor plates and some store bought legs a lot flimsier than the ones you are making. I can assure you that that connection will take all the 'flopping' you want to throw at it....and then some!
    12,256
    Thanks Ted thats just the kind of news i was hoping for.
    30,017
    On the other hand, we've got two large couched that have at least one broken leg each due to 90-100 pound dogs jumping up on the couch to look out the front window. And I thought they had good connections. Never underestimate the damage potential from boisterous kids and animals.
  1. Tennessee wall hanger
    By John Daugherty in forum Flatwork Project Showcase
    Last Post: 10-11-2015, 12:06 AM
  2. wooden clay pot hanger
    By bob martini in forum Designs, Plans and Sketches
    Last Post: 06-21-2009, 04:36 AM
  3. Bolt Question
    By Ned Bulken in forum Carpentry and Construction
    Last Post: 06-05-2007, 09:52 AM
  4. Kay hanger for new home
    By Yann Arbour in forum Flatwork Project Showcase
    Last Post: 04-27-2007, 04:05 AM
  5. Quilt Hanger
    By Sean Wright in forum Flatwork Project Showcase
    Last Post: 03-30-2007, 02:50 AM
