Results 1 to 10 of 23
Thread: Drill Bit Stuck in Ryobi Drill...Now what? HELP!!
    Jul 2007
    DSM, IA
    5,719
    Last night I was drilling a 1/2 hole and used my Ryobi drill. Drilled the hole and went to take out the bit....can't loosen the chuck. Any ideas?
    BTW, it's still under warranty, but I can't find my receipt to take it to HD...think I would need it?
    My Website
    Southeast Pa
    2,019
    keyed or keyless chuck?
    30,002
    Quote Originally Posted by Garry Foster View Post
    And how are you trying to loosen it? If it's keyless, are you just twisting the chuck by hand, or are you using the drill's motor for torque?
    Jul 2007
    DSM, IA
    5,719
    Keyless, and using the motor to release the chuck...always done it that way. Is that not the right thing to do? Will give it a go tonight with 2 hands...
    My Website
    Oct 2008
    1,357
    I had that happen on my old DeWalt 14.4 1/2" drill sometime back. I ended up putting the chuck in the wood vise and then pulling the trigger by just "tapping" it. It seemed using your hand didn't transfer the shock needed to loosen the chuck. I guess you could say your hand acted like shock absorber. YMMV
    Aloha,
    Yeah, two hands if the chuck is in two sections. From a manual:
    Keyless Single Sleeve Chuck (Fig. 68)
    WARNING: Do not attempt to tighten drill bits (or any other
    accessory) by gripping the front part of the chuck and turning the
    tool on
    . Damage to the chuck and personal injury may result. Always
    lock off trigger switch and disconnect tool from power source when
    changing accessories.
    I'm sure we all do this to snug the bit and to change the chuck openings for different size shanks but, hand twisting to tighten and to loosen is the rule. Your drill motor doesn't like being used to final-tighten or unlock the bit any more than it likes being ground to a halt under power. Its hard on the tool. I know we all see folks do this on a regular basis. These may also be the folks that complain about a tools quality after 6 months of abuse . I do use this method when installing hex shank driver bits since they only need to be snug for my use. Anything that needs to be torqued down in a keyless chuck should be done by hand as far as any manual I can find. This would include nearly all loosening operations, no? I try to follow this every time and may succeed 80-90% of the time .
    Jul 2007
    DSM, IA
    5,719
    Keyless Single Sleeve Chuck (Fig. 6–8)
    tool on
    Guess I probably knew this...but never really paid attention to it. Thanks!
    My Website
    Feb 2012
    2,746
    The one time this happened to me, I clamped the chuck in my vise and turned the drill. It came loose without damage.
    Cheers,
    Roger
    30,002
    I've known it for years. And ignored it. Heck, I was using the "hand grip" method even before keyed chucks were popular. I do use the key on bigger drills, lathes, and drill presses. My current drill press has a keyless chuck, and someday I'll swap it out for a keyed chuck just because it's easier for me to get things good and tight with a key.
    Jul 2007
    DSM, IA
    5,719
    Great minds think alike...errr...nevermind
    My Website
  1. Anyone Used this Drill ?
    By Mike Turner in forum New Tools
    Last Post: 11-21-2014, 07:30 PM
  2. Drill Box
    By Dan Mooney in forum Flatwork Project Showcase
    Last Post: 01-11-2012, 08:35 PM
  3. Drill Bits
    Last Post: 10-17-2010, 05:02 PM
  4. The Drill I did not like
    By Bartee Lamar in forum General Woodworking Q&A
    Last Post: 07-17-2007, 03:01 PM
  5. To drill or not to drill
    By chris johnson in forum General Woodworking Q&A
    Last Post: 01-21-2007, 11:47 AM
