Results 1 to 10 of 16
Thread: Metal T track alternative
    Mar 2014
    Montreal , Quebec , Canada
    3
    The use of T nuts and a track provides great functionality in many purchased and home made jigs, providing for easy positioning and securing of components, movable travel stops, hold downs and other valuable uses. I enjoy looking at the pictures and write-ups on the large variety of ingenious jigs that appear on this and other woodworking forums. They almost all incorporate one or more metal T tracks to enhance their functionality.
    I too have made many jigs incorporating t-nuts but have never used a metal T track. I use a T slot router bit to cut the slots directly into the jig material. I use a 5/16” straight cutter bit and rout a dado 3/8” deep using 2 or three passes and then finish with 1 pass of the T slot bit set to match the 3/8” depth. For my jigs I use either Baltic Birch or hardwoods such as maple or oak and have never had one fail on me as in breaking the slot when torquing down hard on a hold down for instance.
    From a cost standpoint you save on not purchasing the T track and producing one is quicker than grooving, fitting and screwing down the metal T track. If you are less than satisfied with your jig and decide to make a new “improved” one, your losses will be less as once you cut the metal track it may not be long enough or suitable for the revised jig.
    The bit I use was purchased from Lee Valley Tools and I am sure that there are other sources for the same kind of bit. For those of you into making your own jigs this might be of interest.
    Pictures attached
    1: The T-Slot bit (picture taken from Lee Valley Website)
    2: Drill press table (T slots for fence positioning, hold downs and fence stops)
    3: Close up of the end of the T slot
    4: Table saw cross cut jig (T slots for fence positioning and hold downs) Some of you have no doubt seen this jig on the internet; useful at times.
    Attached Thumbnails Attached Thumbnails T-Slot bit.jpg   T-slot end.jpg   Drill press table.jpg   Table saw cross cut jig.jpg
    Jan 2011
    3,798
    That's great Robert, especially for those of us watching our pennies...Thanks for sharing and welcome to the family!
    10,604
    I've always wondered how well they would work. Thanks for the tip !!!!!
    Welcome to the family Robert !!
    12,251
    Robert as Bob says welcome to the family.
    Thanks for the feedback on those bits, i too have wondered how well the slots work out.
    Yorktown, Virginia
    5,014
    Robert,
    Welcome to the family. Glad you found us and thanks for the tip. Looks like that bit does the job.
    Nov 2010
    Arkadelphia, Arkansas
    139
    Welcome to the family Robert. Great tip. Prior to reading your post count me among the, 'It looks good, but I wonder if it works' folks.
    Norm
    I have a mind like a steel trap....
    ....rusty and illegal in 29 states.
    Mar 2014
    3
    Thanks for the nice welcomes, it gives a warm feeling and motivation to greater participation.
    Regards to all.
    Apr 2008
    Independence MO
    561
    I find this interesting and wonder if you have ever used that in MDF (one time jig/template thing)?
    Also, have you ever found that it was better to use a metal track? (long term item, such as a router table fence, verses remaking it)
    Thanks
    Quote Originally Posted by Randal Stevenson View Post
    Thanks
    Not trying to answer for Robert but, I will share my experience, such as it is. I use both. the only time I have had a t-slot cut into material fail is when I used one in BB plywood but, I guess I should have seen that one coming. The application was a for a holddown and the ply delaminated under stress. I have used slots in hardwoods that have a tight grain like Beech and maple without issue. For t-slots in MDF I have also been successful for things like stop blocks and featherboards (shearing pressure) but, would hesitate to use this for holddowns (pullout pressure). MDF has no grain and, just as with shallow screws, slots have minimal pullout resistance.
    For stop blocks in MDF slots I use a tongue that is just shy of the slot depth to avoid crushing the material while tightening. A screw is a very powerful 'machine' and a dented or crushed section of MDF material can make sliding difficult or lead to material failure under stress. For my type of featherboards in MDF slots I just have to remember to use only the amount of tension required to hold the jig and take care not to crush the materiel.
Name:	Stop Block in MDF (1).jpg
ID:	88126 . Click image for larger version.
Name:	Stop Block in MDF (2).jpg
ID:	88127 . Click image for larger version.
Name:	Stop Block in MDF (3).jpg
    One of my efforts in my jig design is to keep things light. This can mean the use of a thinner material than one that would support a slot for a holddown function. In those cases I use track. The MDF slots I have for stop blocks and featherboards have been in use for many years without failure. My router table top also uses t-bolts in MDF through-slots to hold the fence. This system also have been in use for many years without issue but, could be prone to crushing problems if you are heavy handed.
    5,172
    @ Glenn: I have not seen the t-track with the right angle mounting leg. Source?
  1. Alternative to Dewaxed shellac?
    By Tom Baugues in forum Finishing School
    Last Post: 11-15-2015, 07:04 PM
  2. Indirect Light Alternative
    By glenn bradley in forum Finishing School
    Last Post: 06-16-2015, 02:01 PM
  3. Any ideas for an alternative??
    By fred hargis in forum Finishing School
    Last Post: 04-02-2015, 07:16 PM
  4. Alternative use of jig and drill press
    By Dan Gonzales in forum Off Topic Discussion
    Last Post: 06-30-2014, 02:51 PM
  5. Anchorseal Alternative
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 05-18-2013, 01:32 AM
