Results 1 to 10 of 13
Thread: Did a test on thursday just for fun.
    12,251
    Here is what raw mahoganny looks like left with Em6000 and on the right hand side is same finish with a bit of general vintage cherry added to give it some color. Helped a great deal to take the plastic look out.
    13,439
    The cherry gives a nice tone.
    Nov 2012
    Wapakoneta, OH
    611
    That is a significant difference. It looks to me like it gave the EM6000 more of an oil base finish tone.
    May 2011
    Cape Cod, Ma.
    1,553
    I do that with the EM8000cv. Finishing schedule is usually as follows. first 2 coats gloss "kissed" with a bit of dye to act as a toner. (dye color varies by project) (I also use the catalyst with the EM8000cv) adjusting color each coat. Sand between coats first 600grit then 800 grit there after. Final coat I add flattening agent to adjust to desired sheen. This way the wood isn't occluded by a build up of flattener in each coat and gives a lot of depth to the wood.
    Looks great Rob!!! Half the fun is experimenting!
    My challenge with mahogany is getting the 'orange' out. Your example on the right is a definite improvement IMHO. Is that surface still pretty rough? What was the surface prep (sanding, planing)?
    5,320
    My challenge with mahogany is getting the 'orange' out...
    Perhaps a tiny touch of green dye in your finish. It won't take much - just a 'hint of tint.'
    12,251
    Glenn this is totally raw from resaw no prep at all. Just wanted to see the difference.
    Jim I will try that once my significant order of more finishing product arrives, one of the things i have ordered is a set of transtint dyes and a color wheel then i can experiment. Also got some gloss on order.
    Been playing with two different small touch up guns and after using Larrys tricks i finally am seeing the light.
    Austin, Texas
    1,448
    The pic on the left is, to me, the problem using EM6000 as a sealer - the color of the wood doesn't come out. That is why I start with 1000, then go to the 6000.
    I prefer mahogany without any color added. For example this pair of bookcases were finished in EM1000 and EM6000, no added color, next to a historic mahogany harpsichord on the left and piano on the right.
    Charlie Plesums, Austin Texas
    Apr 2009
    Outside the beltway
    5,250
    Rob your learning brother. Now if you want to try adding a few drops of green and do a test. Cherry/Mahogany is sweat I use it a lot when finishing both cherry and mahogany but I add the green to cool the red a bit.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Thomasville, GA
    5,992
    Quote Originally Posted by Dave Hawksford View Post
    I've tested using TT green and it worked pretty well. On one project about ten years ago, the client wanted mahogany but not so much red, as usually happens. I did several tests and the best result was using TT Dark Mission Brown. On some woods, the TT DMB looks kinda muddy but it had the desired result of reducing the redness of the mahogany.
    Bill Arnold
  1. Thursday Twofer! Happy Birthday Jim Hager and Joe Mioux!
    Last Post: 04-12-2013, 02:08 PM
  2. I got the Thursday afternoon blues
    Last Post: 10-26-2012, 07:58 PM
  3. Thursday wake up one more day till FRIDAY !
    Last Post: 02-03-2012, 03:34 AM
  4. Thursday Paddle
    Last Post: 08-24-2009, 04:17 PM
  5. Going to Vegas Tuesday. And Wednesday. And Thursday.
    Last Post: 04-27-2008, 08:35 PM
