Results 1 to 10 of 18
Thread: First Bench
    Jan 2011
    3,798
    First Bench
    That hopefully will pass the test of time...
    Ponderosa pine base, MDF top, wrapped in curly maple...
    Mortise and tenon legs and stretcher...
    Doweled top support...
    Cross members...
    Coat of epoxy on the knots...
    Dummy forgot to joint the factory home depot lumber, and the results of the eased edges made the joints look sad...
    So, backsawed and chiseled out a cosmetic fix...
ID:	88261 > Click image for larger version.
ID:	88262 > Click image for larger version.
    Did the same sorta fix at the stretcher ends...
    Then decided to add a decorative touch with the hope it may add in strength at the joint, though it's only a quarter inch deep...
    More in a minute or five
    Jan 2011
    3,798
    Then it was onto surface flattening the base, probably over-kill, but my floor slopes fairly well...
    onto a couple of coats of BLO & MS...
    Followed by top time...3 layers MDF...
ID:	88268 > Click image for larger version.
    and wrapped in maple...
ID:	88270 > Click image for larger version.
    Vise tip was to make the handle before assembly...
    Then glue up of the vise faces...
    Then layour for screw and guide rods...
    And recessing the guide supports...
    just a few more, lol
    Jan 2011
    3,798
    Attaching the bench side vise face...
    Vise shim and anti-slide corner blocks...
    Dog hole jig and drilling came next...
    angling the face vise via planner jig...
    took a break to add a descriptive note...my woodworking at times can be a battle, LOL not sure if that's a horse, Lion or combo, similar to some of my creations in that aspect ...cut the pattern on the scroll saw and traced to the top, then pyro'd in with my wood burner...it is what it is...
    and these last shots are after the second coat of Blo, MS, Minwax Antique oil and a dash of Poly satin...more coats to come followed up by some paste wax...
ID:	88281 Click image for larger version.
ID:	88285 Click image for larger version.
    Thanks if you made it this far was a ton of fun!
    Oliver Springs, TN
    1,726
    That looks great Ken! A proper bench is on my short list. I've finally gotten tired of trying to cobble something together to hold something that a bench will do in a few seconds.
    13,353
    Fantastic!
    Now make sure you keep all the glue stains off of it!
    Yorktown, Virginia
    5,002
    She's a beauty, Ken. What's her name?
    Yay! She looks great Ken
    Nov 2010
    Arkadelphia, Arkansas
    139
    Really super Ken!!! I'm with John, a serious bench is on my short list and fast working its way to the top.
    Norm
    I have a mind like a steel trap....
    ....rusty and illegal in 29 states.
    5,167
    Harkening back to the teaching days. Students would build a bench after several semesters of other wood working classes and then remark, "I wish I had done this in the beginning."
    Would save so many mistakes. A good bench is a good tool. Not just a place to spatter glue, spill paint, and pile stuff on.
    Apr 2008
    Independence MO
    557
    Quote Originally Posted by Ken Cook View Post
    If I got the right picture, I went by it to quick and saw those foosball men, instead of spring clamps with the green.
  1. New (for me) RAS going in the bench
    By Robert Horky in forum Carpentry and Construction
    Last Post: 10-09-2012, 10:47 PM
  2. New Orleans Saints Bench { Final Bench }
    By Marshall Border in forum Flatwork Project Showcase
    Last Post: 03-30-2012, 02:23 PM
  3. Repurposed bench materials - dedicated sharpening bench
    By Darren Wright in forum Carpentry and Construction
    Last Post: 12-31-2010, 05:25 PM
  4. Re-done Bench Top
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 02-27-2009, 12:00 AM
  5. Bench Dog
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 10-28-2008, 11:18 PM
