Results 1 to 6 of 6
Thread: entry lock disabled question
    17,470
    i have a old quickset lock that needs to look right but not lock anymore.. anyone got some ideas?
    Jan 2011
    3,798
    Simplest/cheapest method is to glue/epoxy the locking knob{the small one you turn to lock/unlock} another is to pull it apart and from the locking knob{again the small one} cut off the rod {not the semi-circle rod} that engages the lock mechanism...hope it helps
    Jun 2007
    4,944
    Larry,
    Once you remove the two screws and look inside you will see that it is easy to do what you want. As usual Ken has a good answer.
    Enjoy,
    JimB
    ps If you have any questions I will take one apart and PM the pics to you. I think I have several of them. I will send you one or more to play with if you wish.
    VOTING MEMBER
    17,470
    Quote Originally Posted by Jim C Bradley View Post
    Larry,
    Enjoy,
    JimB
    thanks jim but i will get this done without samples i thought it was possible just wanted to refresh my memory its getting dusty thats how i thought i had one long time ago ken. thanks again
    North West Indiana
    6,097
    Randi locking you in or out of a room and getting tired of it????????????
    Jon
    Tellico Plains, Tennessee
    4,351
    Larry, if you open the lock, there should be a series of pins that are spring loaded to fit the key...... when a lock is re-keyed they just change those pins to fit the key, so removing those pins should disengage the lock.
    Chuck
    Tellico Plains, TN
  1. Disabled Veterans Golf Course
    Last Post: 12-23-2010, 01:08 AM
  2. Woodturning Symposium for the Blind or Disabled
    By Steve Russell in forum General Woodturning Q&A
    Last Post: 12-14-2009, 10:30 PM
  3. Entry in FWW Contest
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 09-15-2009, 05:17 PM
  4. Hnadicap/disabled furniture?
    By Al killian in forum Designs, Plans and Sketches
    Last Post: 08-16-2009, 01:57 AM
  5. Disabled vet question
    By Kirk Constable in forum Off Topic Discussion
    Last Post: 01-09-2008, 03:48 PM
