Results 1 to 10 of 16
Thread: toilet recomendations!!
    17,472
    toilet help, looking for a tall one that works well, as in big gulp and not plug 50% of the time.. my parents are old and need a higher one than the low boys out there and water consumption is not an issue, flushing away the left overs is number one priority.. one inthe big box stores would be handy but i have access to a real plumbing shop as well..
    Thomasville, GA
    5,992
    Bill Arnold
    5,321
    Kohler "Chair Height" AKA "Comfort Height."
    We've had two of them for about the past 7 or 8 years, and they've worked flawlessly.
    Jan 2011
    3,798
    Another on Kohler, we have one that the paper-work says> model K-3496, K-3497, K-3499 but couldn't tell ya which as there's no markings other than Kohler 1.6gpf on it{there is a control to lower it to 1.4gpf}.
    It's 16.5" high from floor to bowl minus the seat. Wife complains everyday about how much difference the higher one makes over the standard ones at her work place{she likes the height of ours}....This one is probably 5-7 yrs old and never a problem {other than the wax ring fiasco, but that's ahem, installer failure not the throne itself.
    Edit: Home depot FWIW
    Feb 2012
    2,749
    I've jsut installed an American Standard Tofino model, which has two flushes, one 4 litre and the other 6 litre. I got it to replace a toilet that plugged constantly, and have not had a problem since I installed it. It is taller than any of the toilets I've had before, but not uncomfortably so.
    Cheers,
    Roger
    Oct 2013
    Central NJ
    21
    I needed a new toilet last year, and after reading a lot of reviews decided on the Toto Drake II. Only 1.28 gal/flush yet works fantastic! It costs more than typical off the shelf toilet from a big box store, but worth it and highly recommended. Home Depot sells this for $536.00 (http://www.homedepot.com/p/Toto-Drak...G-01/204399649), but I found it for almost $200 cheaper here where I bought it: http://www.homeclick.com/toto-cst454.../p-308657.aspx.
    Definitely worth a look.
    Nov 2012
    Wapakoneta, OH
    611
    American Standard keeps changing the model names, but we have 2 called "Champion 4" and 2 called "Cadet 3"; all are comfort height and elongated bowl. Most importantly, all of them have an excellent flush. After 5 years with them (I put them all in right after we bought this house) I've only had to replace on the seals on a Champion $. I wish I could figure out what the current name is for these, it may be the Tofino Roger mentioned. These are readily available at the Lowes. (should mention, the Cadet is 1.28 gallon per rflush, the Champion is 1.4).
    Toto does take this area to a science.
    3. Comfort Height vs. Standard Height
    TOTO toilets are available in two different heights. Universal Height, also called Comfort Height or ADA Compliant Height, measures between 17 and 18 inches from the floor to the top of the toilet seat. Government regulations require public restrooms (essentially any outside of the home) must be ADA Compliant height.
    The Standard Height toilet is almost 15 inches from the ground to the top of the seat. ADA Compliant Height toilets are becoming very popular in homes as they are comfortable and favored by the elderly.
    Oct 2013
    Central NJ
    21
    We have the Universal Height and love it. Also, I understand that the lower per-gallon-flush toilets do not always have enough water to clean "remnants" on the bowl, but the Toto has a finish they call SanaGloss that seems to act like Teflon - nothing sticks to the bowl when you flush - http://www.totousa.com/people-first-...anagloss%C2%AE.
    It was also nice to see our water bill come down. The toilet it replaced was there when we bought the house 20 years ago so I'm guessing it used at least 5 gal/flush. With 4 people in the house, it adds up.
    3,134
    American standard Cadet 3 is the one we used in the apt complexes, it has a larger discharge hole at the bottom of the tank. I dare you to put the lid down flush the toilet & pick up the lid fast enough to see it discharge. The bowl will already be empty. We had a 3" main under all 11 buildings instead of 4" this made that system work much much better. I installed several of these toilets over the years I was there both handicapped & regular height toilets. If you want stress & what it can do to you try managing apts. for 17 years.
  1. Welder Recomendations?
    Last Post: 01-31-2012, 09:34 PM
  2. $300.00 - $100.00 toilet
    Last Post: 01-28-2010, 04:29 PM
  3. Drawer wood recomendations
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 10-18-2008, 04:33 PM
  4. Cyclone recomendations / which do you use
    By Dan L Clark in forum New Tools
    Last Post: 08-30-2008, 09:18 PM
  5. Dust Collection Recomendations
    Last Post: 04-10-2007, 02:17 AM
