Results 1 to 10 of 19
Thread: Recommended Spray Adhesive?
    Could you guys recommend me a spray adhesive for temporarily applying patterns? I've got a pattern I want to print out on standard printer paper, stick to a piece of oak, then drill, cut, and shape the edges, then peel the paper off without resorting to planing it off. In the past, I've tried to use a very very thin coat of wood glue to secure the paper, but it never works out... either too little (pattern comes off in the middle of work) or too much (pattern doesn't come off at all).
    Thanks.
    Yorktown, Virginia
    5,022
    David, I use 3M Super 77. When you are finished, put some mineral spirits on the pattern and it peels right off. Wipe off the residue with a paper towel.
    Aug 2014
    St. Mary's, Georgia
    398
    Agree with Ted its what I use here
    https://www.facebook.com/BgCouger
    If you are going to make something nice, make it with a statement, use quality an do it right the first time
    Thanks guys. Sounds unanimous.
    On removal - you're saying I soak the pattern through with paint thinner and it'll come right off?
    S E Washington State
    3,777
    Ted hit it!
    "We the People ......"
    3,134
    Yorktown, Virginia
    5,022
    Quote Originally Posted by David Agnew View Post
    Don't know about paint thinner. Mineral spirits has worked for me.
    Thomasville, GA
    5,998
    ... On removal - you're saying I soak the pattern through with paint thinner and it'll come right off?
    I use acetone to remove the pattern and adhesive. It dries in seconds and there's no residue.
    Bill Arnold
    Independence, Kentucky
    1,355
    I have the #77 right now that I am using, but I have used the spray adhesive that Wally World sells and it worked just as well and was cheaper. Like Bill, I use acetone to remove the pattern and residue with good results.
    5,323
    Naphtha works, too.
  1. Replies: 0
    Last Post: 03-23-2015, 03:14 PM
  2. Spray adhesive?
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2013, 03:38 PM
  3. Recommended lathe height
    By Rob Keeble in forum General Woodturning Q&A
    Last Post: 01-07-2013, 05:16 AM
  4. Recommended Table Top Finish
    By Darren Wright in forum Finishing School
    Last Post: 06-03-2011, 03:24 PM
  5. Spray on Adhesive that lets go when done...?
    Last Post: 02-22-2007, 11:48 AM
