Results 1 to 8 of 8
Thread: SketchUp Practice
    SE Minnesota
    2,524
    SketchUp Practice
    I haven't posted any practice pieces for awhile so I thought I'd share this one. It's a small Sheraton-style table based loosely on one by Mario Rodriguez. I was really only interested in the legs when I started. They turned out to be pretty simple so I doodled up the table. There's probably going to be a tutorial on parts of this in case there's interest.
    13,436
    I would be interested. Might be good practice for me to go back and re-draw my high chair for plans.
    That leg turned out to be deceptively easy....
    I drew a 12-sided circle.
    Drew a half-circle arc on the flat of one of the sides.
    Cut a pie slice and made it a component.
    I extruded it
    I scaled one end of it to make the taper.
    I then did a radial copy of the component
    Then I built a cone and made it a group
    I copy/pasted the cone into the component and did an "intersect with context"
    then deleted the group and the waste portions of the component
    finally traced a line on the component so Sketchup would re-fill the arc
    I'm sure there was a better way to cut the angle, but I'm supposed to be working in my physical shop downstairs, not the digital one up here!
    SE Minnesota
    2,524
    Darren, it would be good practice to go back and redraw your high chair. I'm sure you would find easier ways the next time around.
    David, that's a good start although it quite a few more steps than I used. Get back to work!
    Here's a close up of the front. should give you an idea of the profile at the top. the tops of the reeds are cut off with a curve instead of a flat.
    I don't know about quite a few... I think a better method to make the angled tops would be to select the half circle, then use the rotate tool to bend it down. However, that's still extra steps b/c you have to build an angled wall at half the angle (15*) between the two sides of the pie and set the Rotate tool's angle to that.
    That's for a flat reed top.
    Other than using a bunch of extensions, I don't see how you could do a more complicated curved cut with fewer steps.
    SE Minnesota
    2,524
    No extensions were used to make the reeded section or cut off the tops of them. In fact, I used only one extension while drawing the entire leg and that was to draw some of the curves in the turned sections.
    I didn't build any angled walls or do most of the steps you came up with.
    It sounds like you have a pretty good idea of how you would draw it so we'll leave it at that.
    Like Darren, I'd be interested to see how you do it so efficiently.
    SE Minnesota
    2,524
    The tutorial is written but we'll have to wait for it to be published.
  1. more practice....
    By Dan Noren in forum Computer-Aided Equipment Project Showcase
    Last Post: 10-09-2015, 08:21 AM
  2. pic practice
    By John Whittaker in forum Site Questions and Test Posts
    Last Post: 08-24-2007, 02:43 AM
  3. Practice run.......
    By Steve Clardy in forum Off Topic Discussion
    Last Post: 04-13-2007, 12:58 AM
  4. Practice run again
    By Steve Clardy in forum Site Questions and Test Posts
    Last Post: 04-12-2007, 07:25 PM
