Thanks a lot for your comments Ryan. I don't quite understand what you mean by "unique titles on each page" do you mean getting rid of the additional information about the material and size?
I'll do my best here since I'm not sure what you're using to do web development and probably wouldn't be familiar with it even if I did
Looking at the "view source" on the web page there is text that looks like:
"<title>Toni Ciuraneta</title>"
This is the same on every page. Ideally there would be a unique title on each of the pages. For instance on the "Design" page you might want
<title>Toni Ciuraneta Product Design</title>
That's probably not exactly the right words to use ... but the idea is to have it be a unique identifier for each page. The search engines will use that as part of the "keywords" to identify the page. So if someone is searching for "Toni Ciuraneta" all the pages would currently be equal. If you added the "Design" to it then that would add that so it would also be more likely to be considered for searches for design. The caveat with that is that there are a ton of variables and this is only one but the more hints you can provide the better.
I see you actually have this set for some pages:
http://toniciuraneta.com/en/dresser/
has a title of:
<title>Dresser | Toni Ciuraneta</title>
You might make also want to make that title consistent with the alt tags as suggested below.
What you you want to say using all texts as links? Links to what?
Again I'm going to the "view source" on the web page here so bear with me on this
Looking on the design page - at the link to the dresser the code looks like:
Code:
<div class="entry__featured-image">
<a href="http://toniciuraneta.com/en/dresser/" class="image__item-link">
<div class="image__item-wrapper" style="padding-top: 150%;" >
<img width="800" height="1200" src="http://toniciuraneta.com/wp-content/uploads/2014/12/comoda01-tcm-800x1200.jpg" class="attachment-blog-big wp-post-image" alt="Material: Mongoy / Erable" /> </div>
</a>
</div>
This roughly says:
For the link to "http://toniciuraneta.com/en/dresser/" use the image "http://toniciuraneta.com/wp-content/uploads/2014/12/comoda01-tcm-800x1200.jpg" and use the "alt tag" of "Material: Mongoy / Erable".
The problem with that is that the alt tag is only on the material and doesn't say anything about the dresser itself.
This text is used by the search engines to get hints as to the keywords for the linked page, and is also used as what is displayed if the image can't be displayed (for instance blind web readers would get the "alt" text for the link although I realize that they aren't your primary market here
Ideally this would be something more descriptive
Code:
alt="Dresser in Mongoy and Erable"
And forgive my ignorance what are metatags? I know about metadata, but not metatags:
They're more or less synonyms.
The idea is to add a description to each page something like:
Code:
<meta name="description=" content="A dresser designed and build by Toni Ciuraneta from Mongoy and Erable.">
I'm punting somewhat on the verbiage, you might want to add other descriptive text. This what's displayed in the search engine when it suggests that link.
See page 4 through 7 of the search-engine-optimization-starter-guide.pdf I linked to for another example.
I have to look at your other suggestions regarding the pics, I used a ready made template and I do not know if what you suggest can be done.
Yeah that's possible.. Some of the templates are annoyingly limited in some regards, and you can spend a lot of time doing
If you let me know which one you used I can take a quick poke at it.
