Results 1 to 10 of 21
Thread: Might Be Time...
    30,014
    Might Be Time...
    ...to buy my brother-in-law some new blades for his Sawzall.
    Here are three blades I pretty much toasted a couple of days ago installing a doggie door through a stucco wall. These were all good quality bi-metal Lennox blades. Two of them were "plaster" blades and the third was a "demolition" blade. By the time I got the hole cut in the exterior wall, they were more like "plastered" and "demolished" blades. These are shown in reverse order. The first one that I used is shown on the bottom of the photo. I just about busted a gut laughing so hard when I pulled the blade out of the wall and saw the total lack of teeth. Kinda explained why the cutting had slowed down so much.
    Jul 2007
    DSM, IA
    5,719
    WOW! That stucco is some tough stuff!
    My Website
    Jan 2009
    Carthage,Mo
    884
    Don't make em like they used to.
    Yorktown, Virginia
    5,013
    Hummm...three new parting tools!
    13,440
    Nice butter knives. For stucco, you might try a 4" or 4 1/2" grinder with a diamond/masonary blade, will make quick work of the stone, then cut through with the sawzall.
    4,698
    Reminds me of when the guy came out to install the long haul wireless at the house. He was trying to use a regular drill bit to go through the concrete siding. I kept saying "you'll need a concrete bit", when he pulled the bit out of the wall the tip just glowed red.
    Jan 2011
    3,798
    When you tackle these types of jobs...you're supposed to grit your teeth, not grind your teeth
    17,472
    if you were to add a spacer block you could get more miles out of those blades you one ate the center out the ends are still good
    Aug 2008
    Reno, Nv
    3,632
    I hope you treat your guitars better! Guess they wouldn't make a good hole for the pups
    East Freeetown, Massachusetts
    3,019
    I have never seen anything so worn.
    You must have melted you way through
  1. Long time lurker first time member
    By James may in forum Welcome and Introductions
    Last Post: 01-29-2016, 06:36 AM
  2. It's time for a Shed Thread -Time to get the roof on
    Last Post: 10-27-2011, 02:26 AM
  3. It's time again
    Last Post: 07-09-2011, 12:06 PM
  4. Wake Up,, its time to get back at it!!!,, we HAVE enough,next time
    By larry merlau in forum Giveaways, Contests, and Swaps
    Last Post: 01-12-2010, 12:37 AM
  5. Wake Up,, its time to get back at it!!!,, we HAVE enough,next time
    Last Post: 12-28-2009, 07:00 AM
