Results 1 to 7 of 7
Thread: Softwood RM Bowl
    Sep 2014
    Creston, BC Canada
    55
    Softwood RM Bowl
    The RM manual states that only hard woods should be used . That was probably because back when that manual was written , the cave man never thought anyone would use flat segmented boards to make a bowl from so there would be no end grain sanding at all .
    A flat one piece board or a laminated one has end grain to sand out on two sides and seeing as the cut out of the rings is never as clean on end grain it takes a lot more sanding .
    This one took ten minutes of sanding after the rings were glued together .Of course no lathe tools were required. Sanding only .
    I used one 22" long x 4 3/4" wide board of 40 to 50 year old cedar hydro pole that was given to me last week and added a little poplar for contrast .
    It is 9" diameter .
    Some of the "stuff I have made since retiring .
    http://www.picturetrail.com/willyswoodcrafting
    And a sampling of some of my more recent "stuff"
    http://s6.photobucket.com/user/Willy...=3&sc=1&page=1
    Feb 2012
    2,749
    Sorry, RM??
    Very nice work!
    Cheers,
    Roger
    Sep 2014
    Creston, BC Canada
    55
    Sorry, RM??
    Very nice work!
    Ringmaster to cut rings out of a flat board to make a bowl .
    Aug 2008
    Reno, Nv
    3,632
    Another home run William...nice contrast!
    Sep 2014
    Creston, BC Canada
    55
    Thanks guys .
    I got three logs from that hydro pole last week and then I quartered them with my chain saw and got these boards from them . I made that bowl out of just one of those boards .
Name:	Logs sawed 2.JPG
    I like the alternating angle pattern in the poplar. It adds a neat head-scratcher to the look.
    Feb 2012
    2,749
    Thanks for showing this. A little searching brought me to a page I had seen before, but forgotten, about doing something similar with a bandsaw. Sometime when I'm older...
    Cheers,
    Roger
  1. A bowl and a bowl tweaker
    By hu lowery in forum Lathe Project Showcase
    Last Post: 11-03-2015, 04:07 PM
  2. not sure bowl
    Last Post: 06-08-2013, 02:48 AM
  3. Bent my bowl gouge.. a 5/8" bowl gouge
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 09-01-2010, 12:57 PM
  4. Bowl #2
    By Nancy Laird in forum Lathe Project Showcase
    Last Post: 08-10-2007, 10:31 PM
  5. 2nd Bowl
    By Ed Nelson in forum Turning Tool Questions and Show & Tell
    Last Post: 08-08-2007, 06:10 PM
