Results 1 to 10 of 11
Thread: Follow me help needed. I think??
    The Heart of Dixie
    4,268
    OK Dave, I have impressed myself with what I have learned in Su and that lot of that is thanks to your helping me through those stumbling blocks I was having. But I have hit a snag I can't figure out and no doubt it is simple!! I am just stumped.
    I was trying to draw an electric motor. The round cylinder is simple. But this motor was to have rounded/radiused ends. I could never figure out how to radius the end on a cylinder! I know it it's got be simple but it has me stumped.
    Got a little trick up you sleeve??
    Jeff
    Custom built boats and Kits
    London, Ontario
    3,383
    from one newbie to another... what if you make two cylinders. First the wider cylinder which is the outside of the motor. Then make a narrower cylinder on the end of the motor. This gives you a stepped end. then you can make the arc in that gap and use follow-me to fill it in? (I haven't tried it, just thinking out loud)
    This is probably a bit of a hack, maybe Dave has a slicker approach.
    SE Minnesota
    2,550
    Actually, Art, your way would work. You could use Offset to make the smaller diameter part on the end of the motor. You could also draw an arc segment on the end of the cylinder and run follow me..
    I'll make a couple of illustrations. Back soon.
    Sacramento, CA
    1,367
    From another newbie to two others (we almost have ourselves a quartet!)
    I wonder if you could do something similar with just drawing a line at the center of the cylinder? Draw the line equal to the depth, then an arc and then follow me?
    Jason Beam
    Sacramento, CA
    SE Minnesota
    2,550
    Here we go. Two methods illustrated here from left to right. If, instead of simply drawing the quarter circle, you drew it so the vertical line was at the center, you wouldn't have to fill in the face on the end.
    Instead of drawing the cylinder to begin with you could a circle and then half the section of the motor including the radiused corner. then run follow me on the profile and you'd have a cylinder with a radised edge.
    Houston, Texas
    2,323
    Wow, That is slick Dave.
    Please join me. Register now.
    Shaz
    Here is how
    The Heart of Dixie
    4,268
    Thanks Dave, thats what was thinking, I obviously wasn't using the 'follow me' tool correctly. Will have to work on that.
    SE Minnesota
    2,550
    Jeff, glad that was some help. Tell me if this helps.
    http://www.brightcove.com/title.jsp?title=804227612
    By the way, I use the keyboard shortcut F to activate the Follow Me tool. So the steps after the profile is drawn and the path (the circle) are select the path, hit F, click on the profile. That's all.
    SE Minnesota
    2,550
    I've been wanting to come back to this thread with another demo to illustrate the use of the Follow Me tool. Here's a new video clip with sound. Does this help?
    http://www.brightcove.com/title.jsp?title=823488481
    Geneseo, Illinois
    61
    Great demo. Dave that was so clear, and made me understand things much better thanks.
    Les
  1. Follow up on gloat
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 12-09-2011, 04:14 AM
  2. Follow-up on Bees
    By Mike Henderson in forum Flatwork Project Showcase
    Last Post: 04-08-2010, 01:13 AM
  3. new commission follow up
    Last Post: 02-10-2010, 11:41 AM
  4. whats in a name - follow up
    By Jiggs Elphison in forum Off Topic Discussion
    Last Post: 06-24-2009, 02:08 PM
  5. Going big follow up
    Last Post: 05-05-2009, 03:13 AM
