Results 1 to 5 of 5
Thread: Slow learning, hard lessons.
    Constantine, MI
    7,891
    Some things I never seem to learn and continue to make the same mistake over and over. I can't be alone in this, so I figured I might start the topic and see if anyone else suffers from the same malady.
    For me, the one lesson I refuse to learn is that random orbit sanders are not meant to flatten, they are meant to smooth. I don't know how many times I have used a ROS on narrow parts or sanded past the end of a board only to find out that the edges are no longer in the same plane as the middle of the part or, in sanding an end, it is no longer a right angle but an arc. All that work at the jointer, planer, table saw to keep the stock flat and square goes right out the window after only a few seconds of abuse from the ROS.
    It seems the ROS, with its convenient hook and loop paper has just too soft a pad to insure that anything you sand will stay flat. Maybe someday I will learn.
    www.wrworkshop.com
    13,361
    Guilty as charged!
    Independence, Kentucky
    1,355
    Oh no, never done that, Not guilty
    Catalunya
    4,632
    I don't own any, but from what I know, ROS are meant to remove material fast leaving the surface smooth as you mention, but not flat. That's why they are widely used in car repairs, they allow to remove the poliester filler resin and or paint following the curvature of the metal sheet and leave it smooth. Obviously if you get close to an edge they eat it before you can even notice.
    If I wanted to leave a surface flat, I would use a belt sander, and a normal orbital one just before finishing, but again I'm no expert.
    Best regards,
    Toni
    East Freeetown, Massachusetts
    3,021
    I've never tried to flatten anything with a ROS - well, almost never, - well, uhhh at least --- Not any more!!
  1. stabilized wood is hard, hard, hard
    Last Post: 12-16-2014, 04:12 PM
  2. Lessons from BW 2013
    Last Post: 07-08-2013, 05:15 PM
  3. Lessons From Your Dad?
    Last Post: 06-16-2012, 11:36 PM
  4. Router bits learning the hard way
    Last Post: 09-21-2010, 10:27 PM
  5. Lessons and tutoring for a beginer
    By Royall Clark in forum General Woodturning Q&A
    Last Post: 02-22-2009, 07:42 PM
