Results 1 to 8 of 8
Thread: ZCI Restore with Epoxy
    I imagine many of us have read or heard about doing this. I find when a member shares actually doing some of the things I've read about, it really brings it home so, here's my contribution.
    I was epoxying something the other day and so prepared one of my ZCI's by applying packing tape along the wear-worn slot on the top surface toward the front. Once I was done with my project I drizzled the leftover epoxy into the slot from the underside.
Name:	ZCI repair (1).jpg
    Once it is set up, you make a new "original" cut just like the first time you used it.
Name:	ZCI repair (2).jpg
ID:	89369 . Click image for larger version.
Name:	ZCI repair (3).jpg
    The picture isn't great but, I think you can see where the epoxy fills in the widened slot.
Name:	ZCI repair (4).jpg
    This sort of wear happens as the material is pulled through the slot during a cut. The phenolic lasts longer than my BB ply ones but, the result is eventually the same. Next time your epoxying something, prepare an old ZCI ahead of time and try it out.
    Nov 2009
    Orange Park Florida
    37
    Great tip. I'm going to have to try it in the future. Thanks.
    Austin, Texas
    1,448
    Clear in the photo, but worth pointing out... you only have to repair half of the slot... where the blade moves down into the table.
    Charlie Plesums, Austin Texas
    May 2010
    Orland Park, Illinois, USA
    278
    Glenn, I have neither read nor heard of this tip (must lead a sheltered wood life). It is a great one. I have some pretty beat up ZCI's which will now get a second chance in the old saw. I may even have to upgrade to phenolic as mine are simply plywood. Finally, I never realized how that SawStop ZCI really locks in, way better than mine that just sits on the for support tabs. I will think about how to incorporate the 'lock it in' concept. Thanks for sharing.
    Jun 2007
    New Jersey
    75
    Question
    Do you think this would work with Bondo?
    Thanks
    Dennis
    Quote Originally Posted by Dennis Thompson View Post
    Thanks
    Dennis
    I haven't used bondo in years so forgive me if I'm wrong but, I think that would work fine. As long as the filler has the grip to survive the impact and is not brittle it sold do well. I just use epoxy since I use it anyway and try to do the repair with leftovers.
    London, Ontario
    3,383
    This is one of those moments for me, as it seems so blindingly simple and brilliant once I see it.
    Great tip, Glenn! (quick, send that one to FineWW and maybe win some fun money!)
    Oct 2009
    Dennison, MN
    512
    Bondo is a vinylester resin, it's probably work just fine.
    "Do, or do not. There is no try."
    -Yoda
  1. Anyone used Rustoleum Restore for decks?
    By Tony Baideme in forum Off Topic Discussion
    Last Post: 06-10-2014, 08:29 AM
  2. Rust-Oleum Restore
    Last Post: 05-28-2013, 02:01 AM
  3. Plane Restore
    By Darren Wright in forum Neander Tool Questions and Show & Tell
    Last Post: 03-28-2011, 08:42 PM
  4. Organ Restore
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 08-29-2010, 07:45 PM
  5. Crazy Mower Restore
    Last Post: 08-06-2010, 08:43 PM
