Results 1 to 10 of 10
Thread: cherry pot call
    Oliver Springs, TN
    1,726
    cherry pot call
    Made this for a friend. I got the cherry a few years ago from another friend. He said his Great-Grandfather had cut it some time around 1920. He used most of it for trim in his house. When I found that out it made my stomach hurt! He had one section around 36" of a 6x6 and told me if I'd make his wife a bowl from it I could have the rest. It's naturally really dark and as hard as superman's kneecap! It has some crazy chatoyance too. The top is glass with a camo sound board and the bottom has a smaller piece of slate inset. Almost forgot, the striker has a purple heart bottom with a madrone burl top.
ID:	89513Click image for larger version.
Name:	cherry bottom.jpg
    Yorktown, Virginia
    5,002
    Nice looking pot, John. I'm having trouble understanding the innards....you have a glass top and underneath that a camo sound board of some other material. Normally the sound board is supported by a narrow pedestal up from the bottom, but with your slate inset into the bottom, what's holding up the sound board?
    Aug 2008
    Reno, Nv
    3,632
    I need a tutorial John...these things look like fun and with all the hunting in the area, padding my retirement can't hurt. Yours looks fantastic!
    12,245
    Thats a beauty both in terms of work and story attached to the wood.
    Would love to hear that call. I like how you worked the end of the stick to facilitate scratching. Must give some cool control to the sounds no?
    You need a brand for your calls.
    Oliver Springs, TN
    1,726
    Thanks guys for all the comments.
    Ted, the way you described is how the innards are put together. The only difference is that I took a 2" forstner bit and drilled a recess for the slate which is 2" diameter. I then took a 1 5/8" forstner and drilled the rest of the way through. The pedestal is still there, it's just larger. The sound board is 3" in diameter.
    Rob, I've had several people tell me the same, but I can't think of one.
    Jim, I'll see what I can do about the tutorial
    Oliver Springs, TN
    1,726
    Jim, here's what I use to make the pot calls. When I make another call I'll try and get some in progress pictures. The jig for marking the holes has a 1/4 inch bolt in the middle. When I first started making them I used my faceplate with a 1/4 inch bolt attached to a piece of plywood, but then I got the collet chuck and it's a WHOLE lot easier and quicker! The bolt is used to center the pins on the call. It might be hard to see, but I took small nails and drove them in the disk and cut the heads off. It leaves a mark showing hole locations. I don't always use the spacer on the chuck, but sometimes it's useful.
    Forgot the picture
    Yorktown, Virginia
    5,002
    Thanks for the picture, John. I still use the bolt in plywood technique and would be interested in seeing how you use the collet chuck. I confess, it's been a few years since I made one and could use a refresher.
    Oliver Springs, TN
    1,726
    Here's how I turn my pot calls. If you have a better/faster way let me know! Times money!
    I start with a 4x4 blank, find center and drill the 5/8's hole. I have a jig with nails driven in plywood with the heads cut off that I mash against the blank to mark where to drill the 3/8's holes. Click image for larger version.
    I have a plywood 4" circle that I use to trace the pot and clip the corners on the bandsaw. I will also use a 4 1/8" hole saw on the drill press to cut blanks too. I don't need to use the bandsaw this way.Click image for larger version.
    I also have a 3 1/2" disk that I use to trace out for the top of the call opposite the side with the holes.
    Here's a shot of the collet chuck set up. I use a 5/8's mandrel.Click image for larger version.
ID:	89601 and the blank attached. Click image for larger version.
Name:	blank on mandrel.jpg
    This is a shot showing the setting of the lip for the glass and starting to set the pedestal that the sound board will rest on.Click image for larger version.
Name:	starting blank.jpg
ID:	89603 I leave the pedestal thick until I get the pot hollowed. Then I'll trim it down to right at 1/8" thick.
    Here's the finished pot. I try and make the bottom right at 1/4 inch and the pedestal for the sound board is between 1/16 and 1/8 below the top.Click image for larger version.
Name:	blank roughed out.jpg
    If you have any questions just ask, I might know the answer!
    Yorktown, Virginia
    5,002
    Thanks for the pictures, John. I don't have a collet chuck and always thought they were for skinny turnings like knitting needles that you inserted into the collet. I didn't realize they had an expansion capability. It obviously holds pretty tight and it's easy to flip the piece around and work on either the front or back?
    Oliver Springs, TN
    1,726
    Yep, that's what's great about them. You just have to be careful not to crack the pedestal! That's why I leave it thick till the very end and then cut it down to 1/8.
  1. maybe I should call this #17?
    By hu lowery in forum Lathe Project Showcase
    Last Post: 06-23-2013, 06:46 PM
  2. What would you call this and where can I buy one?
    By John Pollman in forum Off Topic Discussion
    Last Post: 03-29-2011, 12:41 AM
  3. Sometimes your better off to call a pro.
    By Jeff Horton in forum Off Topic Discussion
    Last Post: 05-27-2008, 09:12 PM
  4. Who to call?
    By Steve Ash in forum Off Topic Discussion
    Last Post: 04-07-2007, 12:55 AM
  5. What do you call this?
    By Jeff Horton in forum Turning Tool Questions and Show & Tell
    Last Post: 03-17-2007, 08:08 PM
Tags for this Thread
