Results 1 to 8 of 8
Thread: Joint Cam
    13,431
    Joint Cam
    Anyone used this cam software for doing dovetails?
    http://www.g-forcecnc.com/jointcam.html
    Austin, Texas
    1,448
    I am not a CNC expert, but I don't recall seeing CNC machines that allow a board to be mounted vertically. I can imagine building a vise like clamp on the end of the table, but will the gantry go beyond the table to cut the vertically mounted boards?
    Charlie Plesums, Austin Texas
    13,431
    Quote Originally Posted by Charlie Plesums View Post
    The spindle on mine is setup where it extends past the end of the table by about 4" - 6". I could probably add a spacer between the mount and Z axis to get a few more inches if needed, which is probably what other owners may have to do. However, with the way everyone is building their own cnc machines, one could build a machine specific to this purpose also.
    Sacramento, CA
    1,367
    I built mine with the overhang in mind, too - i can hold up to about 40" boards and reach their ends pretty easy.
    Darren, I haven't seen this before - i'll take a look, for sure
    Jason Beam
    Sacramento, CA
    East Freeetown, Massachusetts
    3,016
    Definately putting that on the must try list.
    Mounting a board vertically is something to be planned into the machine design
    If the "X" axis has two drives on the rails, the middle of the machine be open and allow a board to be mounted vertically.
    Thomasville, GA
    5,990
    Makes me think about putting a "trap door" in the middle of my CNC! Kinda wish I'd a thunk about that before, but I could remodel my system. Just what I need - another project!
    Bill Arnold
    12,246
    Bill thats what first came to mind for me when i saw Charlies good point. Why not just mill a slot and a insert that covers it. Of course it means that slot needs to end up going all the way through the bench. Cool piece of software the guy has created Darren. I would have liked to see him shoot a video of it working on his setup rather than just showing it in drawings in his videos of how it works that are on his site.
    Sacramento, CA
    1,367
    For many reasons, I don't like the "hole through the table" idea. Not the least of which is workholding - you'll need a way to hold stuff in place - and a way to get in there to do that. Wrenches, clamps, screws, etc all need clearance to fasten. Plus, if your gantry is a closed loop, you would be restricting what moves can be made while something is mounted in that hole (i.e. if it has a bottom crossmember (which would make it very rigid), it would not be able to travel past your board sticking down below). Doesn't seem like a big problem, but could be.
    I very much prefer the "hang off the end by 3-4 inches" style for handling vertical boards.
    Jason Beam
    Sacramento, CA
  1. How would you cnc a corner joint
    By Rob Keeble in forum Programming, Troubleshooting, and Q&A
    Last Post: 09-27-2014, 10:57 AM
  2. Box Joint Jig
    By Dan Mooney in forum Jigs and Fixtures
    Last Post: 01-05-2012, 01:10 PM
  3. Finger joint Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 01-23-2010, 10:26 PM
  4. seeking name of joint
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 09-30-2009, 11:49 PM
  5. M and T joint ?
    By jim capozzi in forum General Woodworking Q&A
    Last Post: 02-01-2009, 04:51 AM
