Results 1 to 10 of 14
Thread: Wood Hinge Boxes
    Yorktown, Virginia
    5,011
    Wood Hinge Boxes
    I've been playing with the new iBox and wood hinge jigs and these are the first products. I'm a bit concerned about the cross grain glue job on the hinges and wonder if they will hold up. They are essentially cigar boxes with fancy lids, but the wife likes them and has claimed first dibs. I'm experimenting with finishes and haven't found one I really like yet. The sides are made from Brazilian koa flooring cut offs that were planed down to 3/8" thickness for use as CBG finger boards, but which ended up being too short. Tops are 3/8" thick and overlap the bottom on three sides to facilitate opening (with arthritic fingers). The bottoms are all 3/16 prefinished plywood, floating in a groove. I'm not real happy with the floating plywood bottom. It would be nice if the bottom was as nice as the top, but I'm not sure how to go about it and not violate the wood movement rules. Anybody glue their box bottoms? I used Titebond II for the glue ups. The inside sides of the boxes haven't been finished. I'm thinking shellac, or maybe just wax. Thanks for looking.
    This one is roughly 9.5" x 11' x 3' with a spalted sweetgum top and 3/8" padouk hinges. Finish is two coats of Minwax Antique Oil.
ID:	89695Click image for larger version.
    This one is roughly 6" x 13" x 3" with a spalted silver maple top and 3/8" padouk hinges . Finish is four coats of Waterlox Original and I'm waiting a while before I rub it out to get rid of the dust nibs.
ID:	89693Click image for larger version.
    This one is 6.5" x 8" x 3" with a spalted silver maple top and 3/8" cherry hinges. Finish is two coats of Watco Danish Oil (natural).
ID:	89691Click image for larger version.
    This one is 6.75" x 16" x 3" with a spalted silver maple top and 3/8" padouk hinges. Finish is three coats ofWatco Danish Oil (natural). This box tried to self destruct a couple of times. My clamps slipped when I was routing the hinge slot on the inside, so there is a boo boo patch, and I accidentally dropped it when I was finishing it and broke a hinge. I was able to use the heat gun to soften the glue and then replaced the hinge.
ID:	89689Click image for larger version.
    12,251
    Holy Crow Ted, those look amazing. I cannot pick a favorite.Oh boy you got some nice lids there. That spalted silver maple is unbelievable.
    I like the wooden hinges , but in the spirit of offering a personal constructive opinion, i would have liked to see them longer for aesthetic reasons. Then I know the lids are made from fancy wood and that punky spalted wood may not make the best hinges but given what guys do with stabilizing, it would have been super wow to see the hinges match the lid material, (at least half ) so they less intrusive in the image of the underside of the lid when open , but that's a huge ask and expectation.
    However i am sure anyone receiving one of these boxes would not even think of what i have mentioned.
    The lids sure steal the show though, the rest of the box kinda does not get a show in.
    5,171
    Lovely, lovely, lovely!
    Yorktown, Virginia
    5,011
    ....I like the wooden hinges , but in the spirit of offering a personal constructive opinion, i would have liked to see them longer for aesthetic reasons. Then I know the lids are made from fancy wood and that punky spalted wood may not make the best hinges but given what guys do with stabilizing, it would have been super wow to see the hinges match the lid material, (at least half ) so they less intrusive in the image of the underside of the lid when open....
    I felt the same way, Rob. This was the first batch and I was following the instructions to use only straight grained, non-curly wood. I think I can use the spalted stuff for hinges if I soak it in thin CA glue first. Those little 3/8" hinges are kind of fragile.
    13,438
    Great looking boxes and hinges Ted.
    564
    When I used to make a lot of boxes I made a few with wooden hinges using plans from the Incra gauge. I have never had one fail even though they all were attached in a cross-grain fashion. I always used complementary but different wood for those hinges because I wanted to celebrate the wooden hinge itself. For me, the only one, where the hinges are just too different, is the third one in spalted silver maple and cherry. The cherry is not complementary to my eye.
    I always used plywood for the bottoms of my boxes, either 1/8" birch plywood for smaller boxes or 1/4" lauan for larger boxes. Everyone tells you not to glue in the bottoms, but I always did on the sides, front and back since they were always constructed with long grain materials running along their length. Never had an issue and some of those boxes are now more than 25 years old.
    Usually, I lined the bottom of my boxes with some kind of plush velour, ultra suede or other fabric suitable for jewelry boxes. This is easy to do by cutting a piece of thin cardboard from a gift box to size where it is about 1/8" or so less in length and width than the inside of the box. Then just wrap it with the fabric by mitering the corners and glue the fabric folded onto the underside of the cardboard with double stick tape. On a few occasions, I veneered the plywood for the bottom with some beautiful veneer, usually a burl if it was supposed to be a man's box.
    I am envious that you were able to find such wonderful wood for lid panels. Your boxes are just wonderful.
    I may be getting a little older physically but mentally I'm still tarp as a shack.
    Jan 2011
    Mount Vernon, Ohio
    75
    I'm not picking a favorite, I can't. All 3 are fantastic and something to be proud of.
    BTW, I usually glue my bottom panel in, as Mike said. Never caused a problem yet.
    Those all look great Ted. What a fun and very personal set of boxes. The absence of metal hardware really focuses the attention on the figured tops.
    17,471
    great looking boxes ted and your wood choices are awesome.. i will dab glue the bottoms in a couple spots or pin nail them..
    Catalunya
    4,632
    Those boxes are great as it is the wood choice. Congratulations Ted!
    Unfortunately I can't find spalted wood here. I try to obtain salvaged logs but no results so far, either they are completely rotten or they are of a non suitable wood.
    While I do like wood hinges, I think that in these specific boxes they do not enhance them but somewhat damage the whole appearance. In such boxes I would have done the kind of hinge that Rob Cosman makes, but this is only my opinion.
    Best regards,
    Toni
  1. Hinge Help?
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 11-07-2011, 09:38 PM
  2. Hinge top for Woodmaster 725
    By David Cherry in forum Jigs and Fixtures
    Last Post: 03-27-2010, 12:12 AM
  3. Small Box Hinge Fix
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 09-09-2009, 12:32 AM
  4. Hinge help
    By John Hemenway in forum General Woodworking Q&A
    Last Post: 07-31-2007, 07:55 PM
  5. 25 cent hinge mortising jig for any hinge
    By tod evans in forum Jigs and Fixtures
    Last Post: 03-20-2007, 12:10 AM
