Results 1 to 7 of 7
Thread: Thinking to buy a vintage tool
    Hi guys,
    I am thinking to buy an old stanley #8 jointer plane and good condition but I wonder if I can replace the blade with one from LN.
    Any suggestions will be appreciated.
    5,281
    Yes, you can.
    LN makes a line of replacement blades specially for the old Stanleys. They're just a tad thinner than the 'real' LN blades, and they work great. Consider getting an LN chip breaker to go with the new blade, too. It's a marked improvement over the original.
    The Heart of Dixie
    4,268
    Never looked but I know a #8 is a wider blade than say a #5. Might want to just check the web sites and make sure they make one for the #8. Probably do.
    Custom built boats and Kits
    Villa Park, CA
    1,407
    Before you buy a new blade, sharpen the one that came with it and try it out. The reason I suggest this is that the blade on a jointer is not as critical as on a smoother. You may find that you already have a good solution in hand.
    Mike
    Ancora imparo
    Nova Scotia's beautiful south shore
    443
    I'm with Mike H on this one. Unless the #8 is part of your physical fitness program, I doubt if you'll spend a lot of time using it. Assuming the Stanley iron has sufficient length, grind it to shape, hone it up and take it for a spin. If you plan to use it mainly for edge jointing, I think that's probably gonna do the trick. If you're looking to face joint lumber or to flatten table tops on a regular basis [raise hands all here who do this] then a superior blade that holds an edge longer and is less prone to chatter would definitely be worthwhile.
    If you're lucky enough to land an early model Stanley with a laminated steel blade, especially a tapered one - then I wouldn't even think of replacing it.
    An LN iron that sits on the shelf from one year to the next for its 30 minutes of use is a poor use of your tool allowance IMO.
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
    3,124
    "I am thinking to buy an old stanley #8 jointer plane and good condition".
    Fidel
    Come right over here see the pretty slope push shove wheeeeeee there he goes. Yep I greased it up special just for you.
    17,450
    Exclamation Boy thats the truth
    Mr c got me afflicted and then bart came and helped me fall over the edge with his finds latly but hey we all gotta have some "vice" er plane
  1. SOLD- Vintage Bench Planes - #3 and #4 -
    By scott spencer in forum Classified Ads
    Last Post: 10-14-2012, 11:23 PM
  2. Who is always thinking of buying a tool they don't really need?
    By keith Boutselis in forum General Woodworking Q&A
    Last Post: 08-16-2012, 07:19 PM
  3. vintage Delta iron...
    By James Edwards in forum Hot Deals
    Last Post: 09-28-2008, 08:43 PM
  4. Thinking about my next tool purchase.
    By Don Baer in forum New Tools
    Last Post: 02-07-2007, 02:55 AM
  5. Well, I'm thinking of a new TS or other tool.......
    By Mark Rios in forum General Woodworking Q&A
    Last Post: 11-17-2006, 10:41 PM
