Results 1 to 10 of 17
Thread: PV glue for bent laminated parts of furniture?
    Catalunya
    4,632
    Hi guys.
    I want to make a piece that needs some parts to be bent laminated.
    Any of you have atempted to make bent laminated parts for a piece of furniture? What glue did you use? I'have a video where they suggest to use an epoxy two component glue (powder+resin) and warn against using polivinylic glue due to its elasticity.
    Have you used PV glue? what results dit it gave to you?
    Any suggestion will be appreciated
    Best regards,
    Toni
    Nov 2012
    Wapakoneta, OH
    611
    Toni, I have used PVA on bent lam, and while I can't prove it they did seem to have more spring back (the elasticity). This could psychological on my part since I don't have way to do 2 glue ups and compare. In any case I switched to plastic resin glue (Weldwood) which has some other advantages (and disadvantages). The drawback: it cures slowly, so it's in the clamps at least overnight....longer in cool temps. Squeeze out can cause nasty cuts. You also have to go through the exercise of mixing for application. The advantages: It dries rock hard (it's a sandable glue) and has a longer open time, allowing you a more relaxed assembly time for clamping. It also has no glue creep like PVAs, that can be important on some pieces, less so on others.
    17,472
    another vote for Freds choice: plastic resin glue (Weldwood)
    Thomasville, GA
    5,992
    I've done quite a bit of bentwood lamination with a variety of woods. PVA (yellow) glue will cause more springback because it's relatively soft. I've seen it on a couple of things I made but it wasn't a killer due to the type of project. I experimented with plastic resin glue on the same pieces to see how much difference it made and there was no springback. That convinced me to use nothing but plastic resin glue for any bentwood work I do.
    Bill Arnold
    Independence, Kentucky
    1,354
    Another vote for plastic resin, zero spring back.
    Dec 2008
    Santa Claus, In
    4,779
    Weird timing on this one.
    I have been watching a video series on FWW and Michael Fortune is building a garden chair using bent lamination's. He uses PVA and when he takes the glue up out of the form, he adds a clamp back over the top for another 24 hours. Not a lot of tension, just enough to keep it's shape. He feels the water induced from the glue causes the spring back issue. From what I have seen so far of the video, he could be right.
    I also watched another set of videos doing bent lams and the plastic resin was used. I dries dark and the user didn't like the look as he was using a light spices of wood
    Update, I went and looked, the user that didn't like the Weldwood changed to Unibond 800. It comes in a couple shades and is easier to match the wood species being used
    Catalunya
    4,632
    Ok guys thanks a lot. Fred, thanks a lot for the link to Welwood in Amazon in this way I can get it here, and shipping is not so expensive. I just placed an order.
    Thanks again to all.
    Best regards,
    Toni
    Nov 2012
    Wapakoneta, OH
    611
    That's a good point about the plastic resin glue drying dark, I forgot about that. You can get agents to lighten the color but they aren't exactly down at the box store. I got some from Veneer Supplies with some glue I bought from them.
    Catalunya
    4,632
    Quote Originally Posted by fred hargis View Post
    How dark? I will be using a padauk which is quite dark and reddish, or maybe oak.
    Best regards,
    Toni
    Nov 2012
    Wapakoneta, OH
    611
    I doubt it will be a problem with paduak. On the oak it's possible you might not be happy with it, though it didn't bother me. But my use was on rockers for a chair. I have a fair amount of the lightener left (the glue is long gone). I can mail you a few ounces if you want. It's just a white powder, looking all the world like flour. But for the actual color of the glue, I would call it a light brown.
  2. Radiused Laminated Platform Bed/Dressers
    By mike marvel in forum Flatwork Project Showcase
    Last Post: 11-24-2011, 01:28 PM
  3. question on laminated wood for bowl
    By Drew Watson in forum General Woodturning Q&A
    Last Post: 11-16-2009, 08:24 PM
  4. Cutting Laminated Counter Top..***Final Stages***
    By Greg Cook in forum Carpentry and Construction
    Last Post: 03-11-2007, 04:30 AM
  5. glue for bent laminations
    By Rick Thom in forum General Woodworking Q&A
    Last Post: 02-19-2007, 02:26 PM
