Results 1 to 10 of 15
Thread: Cottonwood Cake Stand
    Mar 2015
    Parker County, Texas
    1,488
    I finished this cake stand turned from a solid piece of cottonwood today. This one and two others were custom ordered for a customer out in Georgia near Atlanta. The top diameter of it is 13" with a total height of 5" and a base diameter of 8". After being roughed out while still wet and green, it spent about a total of a month in my kiln turned down to about 80 degrees. I don't like drying soft woods like this any hotter. After it was sanded down I sealed the wood with walnut oil. After it was soaked in good I finished it out with a walnut oil and shellac mixture. Hope the photos attached this time.
    13,427
    It appears that your attachments didn't get attached. Typically this happens if it's been more than an hour before you click the post button after uploading them.
    Mar 2015
    1,488
    Hi Darren. I just re-attached. I attach them right after I write the post and half the time they are there. Otherwise they aren't. Hope they show up now. Thanks, Dave
    17,470
    dave go into advanced mode and after you place them do a preview of the thread to see if they are there ..right now they are not.
    Mar 2015
    1,488
    Thanks, Larry. That is actually what I do, and I see the photos just fine. Even when I am not logged in and just view the thread, I see them just fine. I don't know why this happens, but it does. Anyway, I redid it again. Hopefully they are there this time. If not, I'll redo it again when I get back. Thanks, Dave
    17,470
    well dave that didnt work either you have posted pics here before and done fine? must a step is missing somehow?
    Mar 2015
    1,488
    Hi Larry. Yes, did it carefully this time. Again. But, I was holding my mouth differently. I have posted photos before and usually have to do it more than once for some reason. I put photos in the albums. Come back later and they aren't there anymore. Guess the aliens took them. Or, a troll. Anyway, I previewed the edit and they were showing. That's all I can do. Funny. I can build my computer from total scratch. I am my own webmaster. But, I can't post photos successfully the first time here. Oh, well. Practice will eventually get it done.
    Aug 2008
    Reno, Nv
    3,632
    It worked! Very nice work Dave. Finish looks like it should hold up well!
    Mar 2015
    1,488
    Thanks, Jim! I rarely use anything but walnut oil and shellac. I once upon a time I used Mahoney's walnut oil, buying it at Woodcraft. But, they moved too far off for me to so I switched brands. Not as good of oil and so I went back to Mahoney's buying it from him online. I keep a gasket sealed decanter jar by the lathe full of it. The shellac I use is Zinser's that I buy at Lowe's. I mix them at about 50/50 and it really gives a nice finish coat that hardens well. I don't ever use lacquers or varnishes. I do keep a spray can of shellac around for when I turn walking canes.
    17,470
    that worked fine and looks great.. glad you got it figured it out
  1. Anti=Gravity Cake
    By William Young in forum The Cook Shack
    Last Post: 11-19-2014, 02:48 AM
  2. Large Cottonwood
    By Paul Gallian in forum Off Topic Discussion
    Last Post: 07-20-2012, 08:14 PM
  3. Cake stand
    By John Ryan in forum Lathe Project Showcase
    Last Post: 12-22-2011, 07:38 PM
  4. Cats playing patty cake
    Last Post: 12-02-2010, 10:58 PM
  5. Cottonwood box
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 11-23-2008, 07:47 PM
