Results 1 to 10 of 16
Thread: no more link belts
    no more link belts
    at least for my williams-n-hussey!......today i smoked, as in melted 3 seperate link belts......all fenners.....went to the local auto parts store and picked up a cogged v belt.....smoother running than the fenners ever where, and when i jambed the moulder the belt squeeled like a stuck hog but never melted like the fenner belts do...........so a 6 dollar automotive belt has found a perminent home where the supposedly superior link belts once resided.
    i`ll keep some fenners for such things as the dust collector where i`d have to crack the babbits to change regular belts, but for power transmission it`s plain ol` cogged v belts from now on.
    hope this post will save somebody a few bucks?.........tod
    Steve Clardy Guest
    So the ol' 5hp smoked em huh.
    4" wide 7/8" deap in a single pass torqued it a bit ......regular belt`s holding up fine!
    37 5'16.25"N 7625'28.11"W
    193
    Been saying that for a long time Tod. Don't get me wrong, the link belts are useful when you'd have to dissemble a machine such as a lathe headstock, but for regular applications a good quality belt will almost always serve you better. Much cheaper, smoother running, better power transmission. While you'll hear lots of folks extol the wonderful results they got from link belts, you have to put it in perspective. These folks are replacing either low quality or old, worn out belts (or both) to Begin with... Any belt would be an improvement!
    On another tack, I'm not sure of the setup on your williams-n-hussey, but if your running only a single belt you might consider going to a double or even triple sheave pulley if your pushing it hard on a regular basis. While there are a lot of variables, generally HP is really starting to push the limits of a single V belt.
    Mike
    mike, when williams-n-hussey designed the machine they did so with a 2hp motor in mind, that`s why they used a single belt. when i set this one up i opted for a 5hp motor.....just a tad more than the factory recomends ...but, i wanted to leave a weak link in the drive train so as not to over torque the spindle......something about several pounds of sharp steel getting loose at 6k-rpm just worries me ....the 5hp never gets hot the way the ol` 2-3 hp motors i`ve ran did, even after 3-4hrs of continious use!
    and so far using the belt as the weak link has proved to be effective...tod
    Central Ohio
    72
    Tod, I hear what your saying. I used to work for a v-belt manufacturer and have seen how a rubber v-belt compares to a link belt when running side by side. I know link belts have there place, but for my money if you can install a standard v-belt you are much better off in cost and performance. I can't understand why equipment manufacturers will put a $0.75 belt on a piece of equipment which costs $1000+.
    Wes Billups
    Central NY State
    3,375
    OK, so how do you know you're getting a "good quality" v belt, and not a cheaply made inferior product.
    Central Ohio
    72
    "OK, so how do you know you're getting a "good quality" v belt, and not a cheaply made inferior product."
    Ken, go to any automotive or industrial supply store and ask for a cut-edge belt. They are manufactured without splices and have cogs or transverse grooves which make them extremely smooth running. Just about any size and length we use in woodworking should be under $10. Don't let them sell you a Kevlar corded belt as the additional strength isn't needed in our applications and can actually be detrimental.
    I believe Autozone is even starting to carry industrial v-belts which is what you want. The automotive v-belts are typically different sizes than industrial belts; ie. different side wall angles and top widths.
    Wes Billups
    Smithville, TX
    358
    I've been experimenting with the Fenner Drive stuff, recently. My drill press likes em, makes speed changes a breeze. My shaper hates em -- similar experience to Tod's. Might have something to do with speed and torgue required for certain machines. A spindle moulder defintely can experience terrific loads. I have always opted for cogged automotive belts in the past with very good results.
    Mini Max Tool Acquisition Mediator.
    "An old man to most kids and a young man to those who are dead."
    www.samantics2.com
    193
    Tod, sounds like you've thought it out and it makes sense to me
    Ken, any good bearing/power transmission shop will have quality belts. The automotive stores are also an option, but jut make sure you get the good quality and not the bargain basement ones. Ask the parts guy which is which, they should know if it's a decent parts store. Personally I prefer to deal with the professional industrial supply and bearing places as they have a reputation to uphold and deal with professional customers who know the difference and expect quality.
    Mike
  1. Link belts for the lathe, do you use them?
    By Randal Stevenson in forum General Woodturning Q&A
    Last Post: 08-01-2014, 06:19 PM
  2. New Belts
    By Chuck Ellis in forum Hot Deals
    Last Post: 12-17-2009, 05:28 PM
  3. Link Belts - Half Off at Amazon
    Last Post: 02-18-2008, 01:33 AM
  4. Source for Flat Belts ??
    By Doug Shepard in forum Old Iron
    Last Post: 07-26-2007, 03:37 PM
  5. Belts vs Variable speed
    By Tony Falotico in forum Turning Tool Questions and Show & Tell
    Last Post: 05-30-2007, 04:39 PM
