Results 1 to 10 of 15
Thread: looking for a suggestion on drilling holes for bottle stoppers
    new york city burbs
    10,188
    If I use an 11/32 drill bit for either penn state stoppers or niles stoppers on wood, its fine. I get a tight fit to use my bottle stopper chuck.
    If I use an 11/32 bit on inlace acrylester its too tight, if I try to force it, the hole chips out.
    If I use an 23/64th bit, the hole is too big for inlace acrylester.
    I tried to use tape over the chuck screw to make it tighter, doesn't work, so now I have 3 blanks that are unusable, but I haven't disposed of them yet, figured Id fill in the holes eventually with something and then redrill.
    whats the solution, something simple Im missing?
    Human Test Dummy
    Toronto, Canada
    276
    Do you use a tap to match your chuck's thread?
    30,014
    Ed beat me to the question. I've always used a tap to cut threads in the hole, especially in acrylics or other plastics. (Don't recall what size the tap or the holes are...been a while since I made any bottle stoppers.)
    Toronto, Canada
    276
    Me neither ... and we made some Niles stoppers yesterday. At least I remembered to wake up this morning.
    new york city burbs
    10,188
    I don't have a tap.
    I never had a problem with regular acrylics, seems only the inlace acrylester drives me up a wall.
    having read ed's response, I think Ill order the niles tap set for future use, have the right size and all.
    its been too cold to do much work out there, so I decided to make a couple of dozen bottle stoppers and not make them again for a while, just keeping busy.
    Human Test Dummy
    Aug 2008
    Reno, Nv
    3,632
    Unlike wood, Inlace (don't know why you bought that crap!) has no ability to expand or contract. Niles uses a 3/8-20 drill bit/tap so where the 11/32" or 24/64" show up at, well...
    new york city burbs
    10,188
    Quote Originally Posted by Jim Burr View Post
    well, dad, I didn't know much difference betweens plastics when I first decided to turn acrylic bottle stoppers, so it looked good, I purchased a bunch.
    my other problem is that I started making only PSI bottle stoppers, but then purchased 30 niles ss stoppers at last years show, and they require a bit different hole, but Ive been ok with wood other acrylics, using 11/32 on wood, 24/64 on acrylic.
    I haven't looked at the niles site, but will get to it. I also cut my blanks short, to get 3 stoppers out of each blank, so when I drilled the hole, I couldn't flip it and turn away the other hole, too shallow.
    Its a learning process for me.........and Im learning to ask first because acrylic blanks are expensive, eventually, Ill work on making my own...not ready for that yet....soon though.
    I don't have anymore inlace left, maybe a pen blank or two.
    Human Test Dummy
    S E Washington State
    3,777
    Could you fill the holes with epoxy and re-drill, when you get the Ruth Niles tap?
    "We the People ......"
    Thomasville, GA
    5,992
    The stopper chuck sold by PSI has a 3/8" screw and comes with a 23/64" drill bit. That leaves only 1/128" of material for the screw to grab. I emailed them about the issue, but they have so much stock they can't make a change. I use a 5/16" drill bit to drill a hole in a blank, then tap it with a 3/8" tap; that leaves plenty of material for decent threads. That process works in wood and acrylic for me.
    Bill Arnold
    Jul 2007
    DSM, IA
    5,719
    I do the same as Bill. 5/16" bit and 3/8" tap. Have had some failures on some punky maple, but nothing else ever. If the wood is punky, I now drill it, cut with the tap, soak in a bunch of CA glue and then re-cut with the tap. That will work about 80% of the time for punky wood.
    My Website
  1. Bottle Stoppers
    By Diana Kell in forum General Woodturning Q&A
    Last Post: 12-18-2013, 07:25 PM
  2. Drilling bench dog holes in a workbench
    By Rich Soby in forum Neander Woodworking Q&A
    Last Post: 03-15-2013, 02:39 AM
  3. drilling 90deg holes with a cordless drill
    By patrick anderson in forum Jigs and Fixtures
    Last Post: 11-28-2009, 01:38 PM
  4. Bottle stoppers
    By Paul Gallian in forum Turning Tool Questions and Show & Tell
    Last Post: 05-20-2009, 09:31 PM
  5. Some bottle stoppers
    By Don Baer in forum General Woodturning Q&A
    Last Post: 11-01-2006, 02:29 AM
