Results 1 to 8 of 8
Thread: The Black Hole
    The Black Hole
    So I'm finishing up the Studio Build and one of the things that was added to the list was trying to quiet the AC vent into the room. It is NOISY and in this small soundproof room, it was not very pleasant. The AC system is old, and seems to have two speeds, too low and too high.
    The vent in question.
    With the vent removed.
    Hard to see but there is a flap up in there behind the sort of louvers that controls how much air can pass through the hold, this is the main source of noise as well as the white vent cover.
    I want to kill the sound but retain the air flow, so my answer is to make the sound change directions but provide enough volume for the air flow to be not significantly reduced.
    I had to make up the metal cylinder that attaches to the metal box in the ceiling, you can see the existing vent on the left and the piece I made to do the same job on the right, this just has the one flat panel that will go tight against the ceiling for now.
    Here is the basic idea.....
    The "W" shaped bit is the bottom the "U" shaped bit fits over it and has the inlet pipe in the middle of it.
    Here it is together, it is upside down on the bench here.
    The idea is that the sound will hit the middle of the W and go to each side, then it will hit the lip or outer edges of the W and again be forced to change direction. The inside of the unit will be covered with sound absorbing foam.
    Here is the unit before it is put together.
    Installed.
    Did it work...?
    Yeah I think so, their is a noticeable reduction in noise, with my iPhone decibel measuring app on my iPhone from 1 meter away it was a steady 72 dB, after the install it has dropped to 59dB, that is a big difference.
    Austin, Texas
    1,448
    So now in addition to everything else, you are an acoustic engineer. Amazing.
    Charlie Plesums, Austin Texas
    17,472
    good fix stu,, so now you need to start looking at medicine and see if you can improve on some things in that field
    Feb 2012
    2,749
    Good solution to the problem, Stu. I would have just turned off the a/c when anyone was in the room.
    Cheers,
    Roger
    Well with 8 people in a room that small for four hours or so, that could get a little......close...
    4,552
    Nice fix Stu they should be happy with that....
    A Turn N Time
    Frog Pond Guitars
    12,251
    Very clever fix Stu. They going to love you at that place.
    Thanks all.
    They used the Studio last night and reported back to me that it went well, the noise was nothing that bothered anyone, so I'll call that one a success too.
  1. Hole Saw Kit ??
    By Paul Douglass in forum New Tools
    Last Post: 02-25-2014, 06:59 PM
  2. Black candy burst/ black sunburst finish
    By Dave Black in forum Finishing School
    Last Post: 11-29-2011, 06:20 PM
  3. The Black Hole
    Last Post: 03-27-2011, 02:35 PM
  4. Drill Press - Drilling large hole over small hole or vise-versa
    Last Post: 12-26-2007, 10:13 AM
  5. Dog Hole Spacing
    By Mike Gabbay in forum Neander Woodworking Q&A
    Last Post: 11-28-2007, 07:38 PM
