Results 1 to 9 of 9
Thread: Bodark Burl Natural Edge Bowl
    Mar 2015
    Parker County, Texas
    1,493
    I turned this bowl during the course of the day. I liked the combination of burl and natural edge to it. The burl mainly shows on the base but you can see it on the bottom of the inside. Also there is a pithy area, though small on the side that I firmed up with some superglue. Wonderful stuff. The bowl is 8 1/2" in diameter, 3" high, and 2" deep. The wood was sealed with walnut oil and polished with a walnut oil/shellac mixture. The base may look at bit on the rocky side but it is quite solid. Thanks for looking!
    4,698
    Neat looking piece of wood!
    Do you do anything special for the bark to stabilize it?
    Mar 2015
    1,493
    Hi Ryan! With this bowl, there was no real need to do anything for the bark. This bowl has the crust layer that's between the bark and the cambium layer. With this I just hand rubbed in some walnut oil and that was that. Then while spinning, rubbed in the walnut oil/shellac finish. With bowls with the bark on them, I use regular superglue in a bead running the full expanse along the bark on both the inside and the outside. When I do the final sanding you can't see the glue. Using the liquid, it saturates into the bark well. Take care.
    11,828
    Neat bowl with a 'rugged' look. How many times did you have to resharpen turning that? Despite it's hardness, I enjoy making things from Bodark a/k/a Osage Orange and about 99 other names. You do realize, I hope, that it will turn walnut dark brown from exposure to light.
    Aug 2008
    Reno, Nv
    3,632
    That looks like a pucker factor multiplier Dave...like the looks of it!!
    Jun 2007
    4,944
    That looks like an "interesting" project that produced interesting results.
    Enjoy,
    JimB
    VOTING MEMBER
    Mar 2015
    1,493
    Yes, Frank. It turns color after so long. I call it burnt orange, but I am not great with colors. On the resharpening. For a smaller project like this, I usually don't have to resharpen. Just have them sharp at the start. I did use all of my bowl gouges. I did the initial roughing with the 3/4", then down to the 5/8, and the rest with the 1/2", Some small stuff on the base I did with the 3/8". I use Hamlets and they hold their edge real well with the harder woods. I actually like them better than Crowns or Sorby's. I don't use the easy tool stuff. I'm a bit more traditional. Thanks everybody for the comments.
    Tellico Plains, Tennessee
    4,351
    That was a good sized tree to get an 8" bowl from... we didn't normally see them that sized when I was down that way... My step father did have a huge one in his cow lot though... not certain how big it was, but I took a few limbs from it that were over 3 1//2" diameter... couldn't reach the bigger ones closer to the trunk.... the main trunk was used as the gate post for his lot... he swung an 8 or 10 foot gate off of it.
    When he was farming, my dad cut every Bodark he could find for pence posts. He put them in the ground green because after they dried, you couldn't drive a staple into them.
    Chuck
    Tellico Plains, TN
    Mar 2015
    1,493
    Hi Chuck! This came from a branch. The main trunk was about 32" in diameter. When you find bodarks in wet areas, they will be pretty good sized like most other trees. I have seen them in this area as big as 4' diameter. Wish I could have gotten that one. It was offered to me but I didn't have heavy enough of equipment to move it once I had it down. I have the saws to take a tree like that down, but in that particular case I would have needed an 18 wheeler flat bed and a large Cat track loader to move it. Oh, well.
  1. Bodark Burl Bowl
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 05-14-2015, 12:39 PM
  2. finish for natural edge of a burl
    By Dan Noren in forum Finishing School
    Last Post: 05-07-2013, 07:44 AM
  3. Buckeye Burl Natural Edge
    By Mark Cothren in forum Lathe Project Showcase
    Last Post: 12-03-2009, 05:01 PM
  4. Natural Edge Redwood Burl Vase
    Last Post: 10-05-2008, 04:24 PM
  5. First Natural Edge Bowl
    Last Post: 02-12-2008, 09:17 AM
