Results 1 to 10 of 10
Thread: I may have discovered the 8th Wonder of the World
    Jun 2007
    4,944
    I may have discovered the eighth "Wonder of the World." I'm sure you all know the other seven such as the pyramids, the sphinx, the hanging gardens. Well I came upon the Eighth by accident this afternoon.
    I am sure all of you, at one time or another, have opened your silicone glue and found that it is now the consistency of a handball. Well I had saved a small amount that only took up about 3/4" in its tube. In the past I have tried wrapping the tube in static cling wrap, sealing the edge of the top where it meets the tube with glue, wrapping with aluminum foil, placing it in a small glass jar, etc.
    Anyway over a year ago I started to throw a dab of glue at the end of a project; like I usually do. Then I thought, "What the heck" I may want a bit sometime in the next month and I saved it. I don't know why but I put it into a 1/2 sized plastic sandwich bag, squeezed out the excess air and zipped it closed. I stuck it into my "glue" box. Well this afternoon I wanted a pea sized dab of silicone glue for something. I figured if I drilled down through the tacky bit that there might be that much in the bottom that was still good.
    I took off the glue tube cap---Lo and behold there was usable silicone glue...the Eighth Wonder of the World.
    Happy gluing and Enjoy,
    JimB
    VOTING MEMBER
    17,471
    your just lucky and the rest of us have to deal with the other endings
    Dec 2008
    Portland, Oregon
    1,898
    Jim, I thought you were the 8th wonder of the world!
    Jesus was a Woodworker
    13,439
    I typically wear the blue nitrile gloves when caulking and such. When I'm done, I'll cut one of the fingers off and slip it over the tip of the caulk tube and wrap masking tape around it a couple of times. I've had good luck with this not causing the tube to dry out, rarely do I have to poke through the top layer to use it again either.
    East Freeetown, Massachusetts
    3,019
    No thank you - I will keep my fingers and throw away the caulk
    10,604
    Quote Originally Posted by Dan Mooney View Post
    Jun 2007
    4,944
    Dan, I don't know what you have been drinking, but I think you better give it up.
    Enjoy,
    JimB
    VOTING MEMBER
    Jun 2007
    4,944
    Dang, there goes my first and only claim to fame!!!
    Enjoy,
    JimB
    VOTING MEMBER
    4,698
    Took the words out of my mouth.
    13,439
    Quote Originally Posted by Jim C Bradley View Post
    No, sorry, wasn't trying to steal away the thunder, was just something that came to mind.
  1. I discovered the best way to cut Polystyrene...
    By Art Mulder in forum Off Topic Discussion
    Last Post: 12-02-2013, 03:56 PM
  2. i think i just discovered.......
    By Rich Soby in forum Off Topic Discussion
    Last Post: 06-03-2013, 12:36 AM
  3. Discovered something new
    Last Post: 06-26-2010, 10:29 PM
  4. Antartica - new penguin discovered
    By Rod Upfold in forum Off Topic Discussion
    Last Post: 12-17-2009, 09:34 PM
  5. I Discovered Sharp Today
    By Brian Gumpper in forum Neander Woodworking Q&A
    Last Post: 11-28-2006, 01:40 AM
